Vector Analysis Homework: Finding the Unit Normal Vector at P
To find the unit normal vector at point P on the surface S defined by w=f(x,y), two non-collinear tangent vectors (u and v) are utilized. The tangent vector u is derived from a plane parallel to the xz-plane that intersects the surface, tracing a curve C at point P. The z-component of vector u is approximated as (∂f/∂x)ux, which is based on a linear approximation of the surface near P. This approximation is valid for small displacements and can be expressed using a truncated Taylor expansion. Understanding this concept is essential for solving vector analysis problems involving surfaces.
manimaran1605
This picture is taken from Div, curl, grad and all that by schey, while finding the unit normal vector of the surface S (defined as w=f(x,y)) at a point P, to find the normal vector he considered a two tangent non-collinear vectors (u and v) at a point P, to find u he considered a plane passing through point P parallel to xz plane, the plane which intersects the surface S traces a curve C which contains the point P, he drawn a tangent to the curve at the point p, let the x component be ux, My question is how the z-component of u is (∂f/∂x)ux ?
No equations found
I have an idea that z-component of u is some approximation, but i havn't learn multivariable calculas a lot, so please enlighten me. Thank you
You are correct. In a small displacement from P, the linear approximation is a good one and you can write ##z(x= P + u_x) \approx z(x=P) + \frac{\partial z}{\partial x} u_x## (The Taylor expansion truncated, ignoring higher order terms). For an infintesimal displacement, this approximation becomes exact.
Likes 1 person
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 85 ·
10K
