How Do You Calculate the Parallel and Perpendicular Components of a Vector?
  • Thread starter Thread starter hadroneater
    Components Vector
To calculate the parallel and perpendicular components of the force vector F relative to vector A, the dot product is a key tool. The parallel component can be derived using the formula F_parallel = |F|cos(θ), where θ is the angle between the vectors. The discussion emphasizes that the dot product A·F equals |A||F|cos(θ), which simplifies the calculation for the parallel component. For the perpendicular component, the relationship A·B = 0 is used, indicating that the vectors are orthogonal. The approach involves applying trigonometric principles and vector definitions to solve for the desired components accurately.
hadroneater
force vector F = 700[-0.25, 0.433, 0.866].
vector A = [-4, 4, 2]
a)What is the component of F that is parallel to A?
b}And what is component of F that is perpendicular to A?
A\bullet F = |A||F|\cos{\theta}
When two vectors are parallel:
A\bullet B = |A||B||
When two vectors are perpendicular
A\bullet B = 0
I'm not sure if I should use the dot product to find the component but I figure that would be the simplest way to do so.
A = [-4, 4 ,2] = 6[-2/3, 2/3, 1/3]
The parallel force vector = s[-2/3, 2/3, 1/3]
That's all I have right now. If I use the dot product equation, both sides of the equation will come to the same term and cancel each other out. I think my definition for the parallel force vector is too general as s could be any scalar.
Note that
<br /> F_{parallel} = |F|\cos{\theta}<br />
(this is obvious if you draw two vectors on paper and apply a little trig)
So
<br /> A\bullet F = |A|F_{parallel}<br />
Then just use the definition of the dot product to calculate the left hand side and solve for the parallel component
