Understanding the Vector Identity and Its Matrix Representation
In summary, the conversation discusses the vector identity given by the equation \left(\mathbf{b}\mathbf{k}\cdot-\mathbf{b}\cdot\mathbf{k}\right)\mathbf{v}=\omega\mathbf{B}. The participants are unsure of the meaning of \mathbf{b}\mathbf{k}, but later determine that it represents the dot product. The conversation also includes a matrix representation of the equation for \mathbf{b}=(0,0,b) and \mathbf{k}=(k_\perp,0,k_{||}), and suggests that \mathbf{b}\mathbf{k}\cdot\mathbf{v}=0 for x and y directions, but
makhoma
vector identity??
The text that I'm reading has a line that reads
[tex]\left(\mathbf{b}\mathbf{k}\cdot-\mathbf{b}\cdot\mathbf{k}\right)\mathbf{v}=\omega\mathbf{B}[/tex]
and I'm not sure what it means by [itex]\mathbf{b}\mathbf{k}[/itex]; it's clearly not the dot product nor the cross product. A line or two below it gives a matrix of the equation:
[tex]\left(\begin{array}{ccc}-k_{||}b & 0 & 0 \\ 0 & -k_{||}b &0 \\ k_\perp b & 0 & 0 \end{array}\right)\left(\begin{array}{c} v_x \\ v_y \\ v_z\end{array}\right)=\omega\left(\begin{array}{c}B_x \\ B_y \\ B_z\end{array}\right)[/tex]
for [itex]\mathbf{b}=(0,0,b)[/itex] and [itex]\mathbf{k}=(k_\perp,0,k_{||})[/itex] which looks like maybe [itex]\mathbf{b}\mathbf{k}\cdot\mathbf{v}=0[/itex] for x and y directions but not for z??Any suggestions?
unknown
see above
[tex]\mathbf{b}^T \mathbf{k}-(\mathbf{b}\cdot \mathbf{k})I[/tex]
Interesting thought there...I'll take a look at that.
Wow that was silly easy. Thanks a bunch for your help arkajad.
1. What is the vector identity and why is it important in science?
The vector identity is a mathematical concept that describes the relationship between vectors and their corresponding matrices. It is important in science because many physical quantities, such as force and velocity, can be represented as vectors. Understanding the vector identity allows scientists to manipulate and analyze these quantities more efficiently.
2. How is the vector identity represented in matrix form?
The vector identity is represented in matrix form using the Kronecker delta symbol, which is a matrix with 1s along the main diagonal and 0s everywhere else. The vector identity states that a vector multiplied by the Kronecker delta is equal to the vector itself.
3. What are the applications of the vector identity in physics?
The vector identity has many applications in physics, including in the study of mechanics, electromagnetism, and quantum mechanics. It is used to simplify calculations and equations involving vectors, and can also be used to prove various mathematical relationships and identities.
4. How does the vector identity relate to other mathematical concepts?
The vector identity is closely related to other mathematical concepts, such as linear algebra and matrix operations. It is also related to the dot product and cross product of vectors, as these operations can be used to derive the vector identity.
5. Are there any limitations to the vector identity?
While the vector identity is a useful tool in many areas of science, it does have some limitations. For example, it is only applicable to vectors of the same dimension, and it cannot be used to manipulate non-vector quantities. Additionally, it may not be applicable in certain situations, such as when dealing with non-linear systems.
