Vector Problem involving Cartesian plane
The discussion revolves around a physics problem involving two particles with different accelerations on the Cartesian plane. Particle 1 accelerates at 5.00 m/s² along the x-axis, while Particle 2 accelerates at -6.00 m/s² along the y-axis, both starting from rest. The main question is whether to calculate the resultant speed of Particle 1 with respect to Particle 2 after 4 seconds, which is found to be approximately 31.2 m/s using the Pythagorean theorem. The conversation also explores an alternative method involving derivatives to find the rate of change of the resultant distance. Clarification on the problem's wording is sought to ensure the correct interpretation of the required calculation.
proster
My main issue is trying to understand the question being asked (is it asking for the magnitude of the resultant vector for speed?)
Particle 1 is moving on the x-axis with an
acceleration of 5.00 m/s^2 in the positive x-
direction. Particle 2 is moving on the y-
axis with an acceleration of 6.00 m/s^2 in the
negative y-direction. Both particles were at
rest at the origin at t = 0 s.
Find the speed of particle 1 with respect to particle 2 at 4.00 s. Answer in m/s.
I know that this is a problem involving constant acceleration so:
v = v_0 + a t One for the x direction and one for the y direction.
So V0x and V0y are both 0. Then, Vxf=(5m/s^2)(4s)=20 m/s and Vyf=(-6m/s^2)(4s)=-24 m/s. Now the problem is whether the problem wants me to find the resultant speed (the wording is somewhat confusing for me). If so, then sqrt(20^2+(-24)^2)) or about 31.2 m/s. If not, I have no idea. I'd appreciate if someone could let me know if I'm on the right track. Thanks!
Hi proster, welcome to PF.
If x is the distance traveled by particle 1 along x-axis and y is the distance traveled by the particle 2 along the y-axis, then
x^2 + y^2 = R^2.
By taking the derivative you get
2x*dx/dt + 2y*dy/dt = 2R*dR/dt...(1)
x = 1/2*a(x)t^2 and dx/dt = V(x) = at.
y = 1/2*a(y)t^2 and dy/dt = V(y) = at.
R^2 = x^2 + y^2 So R = sqrt(x^2 + y^2)
Substitute these values in eq.(1) and find dR/dt.
Thanks a lot! I got the same answer as the way I did it the first time, but it's definitely an interesting way of thinking about the problem.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
