Vectors: How to prove the BAC-CAB identity w/o components?
16 replies · 6K views
Master1022
Prove that $$\bf{ a \times ( b \times c ) = \phi [ b(a \bullet c) - c(a \bullet b) ]} $$
for some constant phi
So I have used the unit vectors i, j, and k and found out that phi = 1.
With the main part of the proof, we are not allowed to expand it using components. Also, I am not at the level where we know the tensors or more advanced methods that I have seen elsewhere on the internet- just the basic rules of dot and cross product.
So I know that $$ a \times ( b \times c ) = p c + q b + k(b \times c)$$ for some scalars p,q, and k. I also know that the a x ( b x c) will lie in the plane of bc, so thus k = 0.
$$ \textbf{a} \times ( \textbf{b} \times \textbf{c} ) = p \textbf{c} + q \textbf{b} $$
Our professor then gave the hint of dotting both sides by a and (b x c) separately and going from there.
So when I dotted both sides by a, I got:
$$ 0 = p (\bf{a \bullet c}) + q (\bf{a \bullet b}) $$
Then when I dotted everything by (b x c):
$$ 0 = p (\bf{c \bullet (b \times c)}) + q (\bf{b \bullet (b \times c)}) $$
This is where I don't know what to do, because the second expression goes to 0 = 0 and I cannot really see how to use it.
Any help is greatly appreciated.
on Phys.org
You dot from the right on the right hand side of the equation. Perhaps try to do that on the lefthand side too ... o:)
[edit] I'll get some coffee first, sorry
BvU said:
You dot from the right on the right hand side of the equation. Perhaps try to do that on the lefthand side too ... :rolleyes:
The inner product is commutative ...
This is what allows you to conclude that there is no ##\vec b \times \vec c## component (i.e., ##k = 0##). Since you have already assumed that, it will come out as 0 = 0.
However, your inner product with ##\vec a## is sufficient for the conclusion that ##\vec a \times (\vec b \times \vec c) = \phi[\vec b(\vec a \cdot \vec c) - \vec c (\vec a \cdot \vec b)]##.
Formula ##\boldsymbol a\times( \boldsymbol b\times\boldsymbol c)=\boldsymbol b(\boldsymbol a,\boldsymbol c)-\boldsymbol c(\boldsymbol a,\boldsymbol b)## follows by direct calculation in a Cartesian frame. This calculation may be little bit simplified if you choose the frame such that ##\boldsymbol a=(a,0,0),\quad \boldsymbol b=(b_1,b_2,0)##
wrobel said:
Formula ##\boldsymbol a\times( \boldsymbol b\times\boldsymbol c)=\boldsymbol b(\boldsymbol a,\boldsymbol c)-\boldsymbol c(\boldsymbol a,\boldsymbol b)## follows by direct calculation in a Cartesian frame. This calculation may be little bit simplified if you choose the frame such that ##\boldsymbol a=(a,0,0)##
I believe this fails the requirement not to use components as specified in the OP.
Thank you for your response! Could you explain what you mean by the above statement- I cannot really understand what you mean.
Thanks.
Orodruin said:
Which of the two statements you quoted?
The second one
To be more specific, you have
You can solve for either ##p## or ##q## in terms of the other here and insert it into your expression
wrobel said:
oh yes, I missed that. Pain without any gain, I see
My gym partner assures me that pain is just weakness leaving the body ... :rolleyes:
I have ended up with $$ \textbf{a} \times (\textbf{b} \times \textbf{c}) = \frac{p}{(\textbf{a} \bullet \textbf{c})} [\textbf{b}(\textbf{a}\bullet\textbf{c}) - \textbf{c}(\textbf{a}\bullet\textbf{b})]$$
do we just let the $$\frac{p}{(a \bullet c)} = \phi = 1$$
Thanks.
The first part, yes (##\phi = p/(\vec a \cdot \vec c)##). That ##\phi = 1## is something you must deduce by using some reference vectors (such as the basis vectors).
wouldn't that mean for non-basis vectors, phi wouldn't be 1?
Orodruin said:
No. The product is linear in all arguments.
That is true... not sure I completely understand why that is, but I have tried it out by setting vectors a, b, and c to random things and they seem to always yield the result that p = (a . c) for the LHS to equal the RHS...
Thanks for all the help!
Why what is? Why the product is linear in all arguments? That follows directly from the cross product being linear in both arguments, i.e., ##\vec a \times (\vec b_1 + \vec b_2) = \vec a \times \vec b_1 + \vec a \times \vec b_2## etc.
