- #1
jrcdude
- 16
- 0
A 50 N sign is suspended by two cables that make angles of 25 degrees and 70 degrees with the horizontal. Determine the tension in each cable.
Cosine law, sine law, or trig
I believe that the teacher's answer is wrong. She did it the same way as the following person:
I did it with the exact same diagram, same angles, but instead of using sine and cosine law, I just used normal trig and divided the tension in half for the triangle's vertical component, resulting in a different answer for the tensions.
This leads me to the conclusion that both answers are wrong, because you cannot just assume there is a 90 degree angle for where the tension hits the horizontal.
Is this assumption correct, and can I have a proper way to do this, with a proper answer?
