How can torque be converted into speed in a vehicle simulation?
In summary: Vehicle mass is 2359 kg so 23118.2 Newtonsthe vehicle is a normal 4 wheel vehicle with about 50% of the mass is on the drive wheels.So the accelerating force at the perimeter of the wheel is 1062/0.49 = 2167 Newtons.Remember that in general power (watts) P = 2 pi RPM/60 x torqueWheel perimeter velocity = street velocity v = 2 pi x wheel RPM/60 x wheel radius (in meters per second)Wheel RPM = engine RPM/3.16
Peetch
I have been reading on these forums for a bit learning about vehicles and their physics. I still have a few questions and do want to clarify some things as well.
I am trying to simulate a vehicle give some basic info you can find online about any car or vehicle. I know Peak HP and the corresponding RPM, I know peak torque and the corresponding RPM and i know the idle RPM and HP. given that info i make a linear graph for the HP of the engine by using the HP = (Torque * RPM)/5252 and its variations. Once i have a close approximation of the HP curve given the vehicles RPM i can then calculate the engines output torque.
I know the gear ratios of the vehicle as well. and they are as follows:
Gear 1 = 3.49
Gear 2 = 1.86
Gear 3 = 1.41
Gear 4 = 1.00
Gear 5 = 0.75
Gear 6 = 0.65
Differential Gear = 1.7
now using EngineTorque * CurrentGear * Differential I will get the torque to the drive wheels.
The part I am a little lost on is if the vehicle is in second gear with the engine RPM at 3000 and using our liner graph the approximated engine HP is 141.47. With that we will take Torque = (141.47 * 5252)/3000 so our engine output torque will be 247.67. Now applying that through the transmission and so on the torque to the drive wheels will be 247.67 * 1.86 * 1.7 and that equals 783.13.
Now this is where I am kinda lost. I know that the torque going to the wheel is 783.13 but how does that apply with MOI and AA and the vehicles speed. Here is other data i know but not sure how to apply it.
Vehicle Weight: 5200 pounds
Wheel Radius: 1.6 feet
again this is my understanding if I an wrong pleas correct any of my steps and please help me understand how I go from torque to the wheel to the speed/movement of the vehicle
141.47 HP x 746 = 105,537 watts
torque = 105,537 watts/[2 pi x RPM/60] = 105,537 watts/[2 pi x 3000/60] =336 Newton meters (torque)
(Are you using non-metric units for torque?)
Torque at drive wheel in 2nd gear is 336 x 1.86 x 1.7 = 1062 Newton meters.
Wheel radius = 0.49 meters
So maximum power-limited horizontal wheel force on pavement = 2167 Newtons.
In lower gears you are not power-limited but friction (torque)-limited at drive wheels. What is vehicle mass M, and what is percentage (pct) on drive wheels? The maximum horizontal accelerating force is
Fmax = pct x M x g x ~80% (for static friction limit).
[added] If your vehicle'e mass is 1000 Kg, its weight is 9810 Newtons.
The maximum force on roadway is 9810 x 50% x 80% = ~3924 Newtons.
Bob S
the vehicle mass is 2359 kg so 23118.2 Newtons
Also how did you determine this?
So maximum horizontal wheel force on pavement = 2167 Newtons.
2359 Kg is a very heavy vehicle. The weight on the drive wheels is ~ 11,570 Newtons. The maximum static friction force on roadway w/o slipping is ~80 % of this, or 9260 Newtons. So it looks like you are power limited.
The kinetic energy of a moving vehicle is W = ½·M·v2
For constant power, the acceleration and velocity are
P = dW/dt = constant = M·v·dv/dt = M·v·a.
Bob S
Maybe you can better explain something to me, How do we convert from drive wheel torque to forward velocity of the vehicle. I am missing something and it isn't making a whole lot of sense.
In Post #2, the drive wheel torque was calculated to be 1062 Newton meters.
The drive wheel radius is 0.49 meters.
Please check my numbers
Bob S
1. What is vehicle simulation?
Vehicle simulation is the process of creating a virtual environment that mimics the behavior and physics of real vehicles. It involves using computer software to model and simulate the movement, performance, and dynamics of vehicles in various scenarios.
2. Why is vehicle simulation important?
Vehicle simulation is important because it allows us to test and evaluate the performance of vehicles in a safe and controlled environment. It also helps in the design and development of new vehicles by providing insights into their behavior and identifying potential issues.
3. What are the applications of vehicle simulation?
Vehicle simulation has a wide range of applications, including research and development, training and education, entertainment, and testing and validation of autonomous vehicles. It is also used in industries such as automotive, aerospace, and military for design and analysis purposes.
4. What factors are considered in vehicle simulation?
In vehicle simulation, factors such as vehicle dynamics, aerodynamics, powertrain, tire behavior, road conditions, and driver behavior are taken into account to create a realistic simulation. Other factors like weather, traffic, and environmental conditions can also be included depending on the purpose of the simulation.
5. What are the benefits of using vehicle simulation?
Using vehicle simulation can lead to cost and time savings in the development process, as it allows for testing and evaluation without the need for physical prototypes. It also enables the study of different scenarios and conditions that may not be possible in real-world testing. Additionally, vehicle simulation can improve safety by identifying potential hazards and risks before actual implementation.
  • Mechanical Engineering
36K
