Calculating Velocity and Acceleration for a Moving Car
The car's distance from a traffic light is modeled by the equation x(t) = bt^2 - ct^3, with b = 2.90 m/s² and c = 0.150 m/s³. The average velocity over the interval from t = 0 to t = 10.0 s is calculated to be 14 m/s, while instantaneous velocities at t = 0, t = 5.00 s, and t = 10.0 s are 0 m/s, 17.8 m/s, and 13.0 m/s, respectively. To determine when the car comes to rest again, the velocity function v(t) = 2bt - 3ct² is derived, leading to two solutions for t: 0 and approximately 12.9 seconds. The conclusion is that the car is at rest again after about 12.9 seconds.
CursedAntagonis
A car is stopped at a traffic light. It then travels along a straight road so that its distance from the light is given by x(t)= bt^2 - ct^3, where b = 2.90 m/s^2 and c = 0.150 m/s^3.
How long after starting from rest is the car again at rest?
Already found
Calculate the average velocity of the car for the time interval t = 0 to t = 10.0 s which is 14 m/s.
Calculate the instantaneous velocity of the car at t=0 which is 0.
Calculate the instantaneous velocity of the car at t=5.00 s which is v = 17.8 m/s.
Calculate the instantaneous velocity of the car at t=10.0 s which is v = 13.0 m/s.
I tried to find the acceleration from v = 17.8 m/s to 13.0 m/s which I got -0.96 but I don't know what equation I need to use to find the time for the car to come to a stop. I don't even know if I am on the right track.
You are given that the car begins at rest and ends at rest. So v(t)=0 at both those times. v(t)=x(t)'. If you set the equation for v(t)=0 you will find exactly two times when the car is at rest. What are they? I think you are doing fine on the other part of the problem.
Ok so I got the equation 2bt - 3ct^2
I plugged in the given values and worked it out.
I got two values for t which are : 0, 12.8888889
I am assuming the 12.9 is the answer.
Am I correct Sir?
Also, thank you very much for the help!
That's the same thing I got. Don't mention it.
