Velocity in Proper Time: Relativistic Acceleration Equation
nomadreid
Two questions, based on the same situation: in
http://physics.stackexchange.com/questions/34204/relativistic-acceleration-equation
(question A) it is mentioned that, for an object with a constant acceleration g_{M}, and with \tau_{0} =1/g_{M} , after proper time \tau, the coordinates are
x= cosh(\tau/\tau_{0})
t = sinh(\tau/\tau_{0})
and that therefore
v = tanh(\tau/\tau_{0})
My first reaction was that this should be coth (position/time, cosh/sinh), but then I figured that tanh comes from v=dx/dt =d(cosh ...)/d(sinh ...) = sinh.../cosh... Is this correct?
(question B) However, this is the end velocity after d\tau. So, I presume one would need to call this v= dv. If we want the end velocity after a finite amount of time, I presume integration would be in order, but since it is the rapidities that add rather than the velocities, I am not sure how this integration would look. Or perhaps there is a simpler method to find the coordinate velocity after finite proper time \tau with constant acceleration g_{M}? (Starting at (0,0).)
I would be grateful for anyone who can untangle me from this mess.
Yes
No, v = dx/dt, as you've calculated it, is the desired instantaneous coordinate velocity at time τ.
Thanks, Bill_K
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
