Velocity of an Object in Uniform Circular Motion
The discussion focuses on calculating the velocity of an object in uniform circular motion with a mass of 0.5 kg, a radius of 2 meters, and a centripetal force of 4 N. The correct approach involves using the equation F = mv²/R to derive the velocity. The participant initially misapplied algebra and struggled with significant figures, leading to an incorrect answer. The correct calculation yields a velocity of 4 m/s, aligning with one of the provided answer choices.
  • Understanding of uniform circular motion principles
  • Familiarity with centripetal force equations
  • Knowledge of algebraic manipulation
  • Basic concepts of significant figures in calculations
  • Study the derivation of centripetal force equations
  • Learn about the relationship between period and velocity in circular motion
  • Practice problems involving significant figures in physics
  • Explore advanced topics in rotational dynamics
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for examples of common calculation errors in physics problems.
Argella
An object of mass 0.5 kg is swung in uniform circular motion. The radius is 2 meters, and the force exerted is 4 N. Calculate the magnitude of the velocity.
Answer Choices:
a) 0.25 m/s
b) 1 m/s
c) 4 m/s
d) 16 m/s
v = 2piR/T
F = mv^2/R
Since I didn't know the variable time, I couldn't use the velocity equation. Next, I tried plugging in the variables for the centripetal force equation and solving for velocity:
4 = (0.5)v^2/2
4 = 0.5/2 + v^2/2
4 = 0.3 + v^2/2 <- 0.3 because of significant figures
(subtracted 0.3 from both sides)
4 = v^2/2 <- 4 because of significant figures
(multiplied both sides by 2)
8 = v ^2
(took the square root of both sides)
v = 3 which isn't one of my answer choices.
Maybe I'm not doing my algebra correctly or maybe I'm not using the right equation, but I couldn't find another equation using the variables I have. If I knew the time it took for one revolution I could use the velocity equation, but I don't know how to find time and I couldn't find an equation for finding it.
Argella said:
4 = (0.5)v^2/2
4 = 0.5/2 + v^2/2
There is an algebra mistake in going from the first to the second step. You have essentially turned a product into a sum instead.
On a side note, when taking significant figures into account, do so only on the final answer. If you keep rounding off at each step, you will find that the rounding-off error grows substantially larger after each step, and the final answer you obtain might be significantly off the correct one.
Ohh, okay, that makes a lot more sense. I'll be sure to keep that in mind about significant figures in the future, too.
Thanks a lot!
