Velocity question i can't figure it out
  • Thread starter Thread starter BUTTER-BENZ
    Figure Velocity
The discussion revolves around calculating the velocity of a baseball thrown straight up with an initial velocity of 10.0 m/s and an acceleration of 9.81 m/s² downward. To find the velocity after 0.50 seconds and 1.50 seconds, the kinematic equation v = u + at is suggested. Participants express frustration with understanding the concept of velocity and seek clarification on the formulas involved. The conversation emphasizes the importance of applying kinematic equations to solve the problem effectively. Overall, the thread highlights common challenges in grasping velocity calculations in physics.
BUTTER-BENZ
Velocity question...i can't figure it out :(
A person throws a baseball straight up from the ground. The baseball leaves the persons hand with an initial velocity of 10.0 m/s [up]. The acceleration of the ball is 9.81 m/s 2 [down]. Assume up as the positive direction.
a. what is the velocity of the baseball after 0.50 s?
b. what is the velocity of the baseball after 1.50 s?
THANK YOU SOOO MUCH IN ADVANCE!
please answer :(
How would you go about solving the problem?
What is it you are stuck on?
For instance I know how to figure it out, but I'm not getting the grade, nor am I taking your tests.
How do you think to go about it?
I seriously have no idea...
this whole velocity is driving me crazy..
can you explain?
well, you know the Kinematical equations.
v = u + at
s = ut + 0.5at^2
v^2 = u^2 + 2as
Use them
can you explain?
let's start by asking you this : what formula's for velocity do you know ?
marlon
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
