Verifying Efficiency in a Thermodynamic System: Q1 & Q2
The discussion focuses on verifying the efficiency of a thermodynamic system using the equations e = 1 - (Tc/Th) and eff = W/Qh. The initial calculations indicate that the efficiency for one scenario is 42%, while another scenario yields an efficiency of 0.35. Participants confirm the correctness of the first calculation and guide the user on solving the second problem through substitution. A mistake in unit conversion is identified, suggesting that temperatures should remain in Kelvin throughout the calculations. The conversation emphasizes the importance of consistent unit usage to avoid errors in thermodynamic efficiency calculations.
Falinox
http://i754.photobucket.com/albums/xx183/reddiesel08/Q2.jpg
e = 1 - (Tc/Th)
(Temp in Kelvins)
e = 1 - (300k/520k) = .42 or 42%
No because the engine can only perform 42 J of work for each 100 J of energy.
http://i754.photobucket.com/albums/xx183/reddiesel08/Q1.jpg
eff = 1 - (Tc/Th)
eff = W/Qh
I know:
e = .35
Th = 180*C + Tc
Tc = Th - 180*
Need someone to verify number 1 for me and to help me solve number 2. Thanks in advance.
Number 1 is right. For number 2, you have all the equations you need. You have
e = 0.35 = 1-\frac{T_C}{T_H}
and
Th = 180+ Tc
So you can solve them together by substitution.
and
Th = 180+ Tc
ok so...
.35 = 1 - [(Tc + 273)K / (Tc + 180 + 273)K]
.35 = 1 - [(Tc + 273K) / (Tc + 453K)]
-.65 = - [(Tc + 273K) / (Tc + 453K)] (divide by -1 on both sides)
.65 = [(Tc + 273K) / (Tc + 453K)]
.65(Tc + 453K) = Tc + 273K
.65Tc + 294.45K = Tc + 273K
21.45K = .35Tc
Tc = 61.29K (convert to *C) = -211*C
This can't be right. Any suggestions on what I'm doing wrong?
You're units are not right. If you put in the "+273", then you are already solving for the temperatures in Celsius, so you don't need to convert in the end. Alternatively, and I think this is easier, you could solve it without the "+273"'s to get the answer in Kelvin, and convert in the end. But you got the right answer in Celsius before you converted.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
