Vertical Oscillation assuming no damping
To determine the frequency of vertical oscillation for a car and passenger system, the effective spring constant must be calculated using the displacement caused by the added mass. The 4.5 cm sink indicates the system's response to the combined weight of the 85-kg person and the 300-kg car. The equations for angular frequency (ω) and frequency (f) are essential, with ω being derived from the spring constant (k) and total mass (m). The discussion highlights confusion regarding the amplitude and the relationship between displacement and spring stiffness. Ultimately, understanding these relationships is crucial for solving the problem accurately.
xelzi
An 85-kg person steps into an experimental car of mass 300 kg, causing it to sink 4.5 cm on its springs. If started into vertical oscillation, and assuming no damping, at what frequency will the car and passenger vibrate on these springs.
ω=√k/m
ω=2πf
x(t)=Acos(ωt)
I thought 4.5 would be the amplitude of the oscillation but then I had 3 unknowns, the distance traveled, omega, and the time. Then I thought it may be the distance traveled and the amplitude would be 4.5/2 but I ended up stuck again.
The amount of sink and the mass of the person are related via the stiffness of the springs.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
