Solving Hard Physics Problem: Flowerpot Falling from Balcony
  • Thread starter Thread starter nemzy
    Hard
To determine how high the flowerpot can fall before a warning is ineffective, calculate the time it takes for sound to travel 16.15 meters (the height of the balcony minus the man's height) at 343 m/s, which is approximately 0.047 seconds. Add the man's reaction time of 0.300 seconds, resulting in a total time of about 0.347 seconds before he can respond. Using the equation y = (1/2)gt^2, where g is 9.81 m/s², calculate the distance the flowerpot falls in that time, which is about 0.5 meters. Therefore, the flowerpot can fall to a height of approximately 17.5 meters before it is too late for a warning to reach the man. This analysis combines physics principles with practical considerations of reaction time and sound travel.
nemzy
A flowerpot is knocked off a balcony 18.0 m above the sidewalk heading for a man of height 1.85 m standing below. How high from the ground can the flowerpot be after which it would be too late for a shouted warning to reach the man in time? Assume that the man below requires 0.300 s to respond to the warning. Take the speed of sound in air to be 343 m/s.
ok, so y=(1/2)gt^2 since there is no initial velocity
but that's all i know, i have no idea how to solve this type of problem
thx
You don't know where the person is so I presume they expect you give an estimate, I would go with something like 20 metres (or just choose a dummy variable if you want), work out how long the sound takes to get there and add the reaction time.
Then work out the time it takes the flowerpot to hit this man using
y = 18 - 1.85 (the distance from the ledge to the man)
Once you have this time, minus the time you worked out above then plus this back into the formulae and you have your answer.
Wow I feel like I am back in my AS level Physics class again lol.
I would assume the person who knocked the flower pot over is the one who will shout the warning. So you find the minimum time before impact by adding the reaction time to the time it takes the sound to travel (18-1.85)m. Then just think about it the way Zurtex described it.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
