Very quick question PLEASE - Star Connection
  • Thread starter Thread starter tissue98
    Connection Star
In a star connection, the phase voltage is equal to the line voltage divided by the square root of three. Given that the voltage sources are specified as 220V, this indicates that the phase voltage is indeed 220V. Consequently, the line voltage would be 220V multiplied by the square root of three, resulting in approximately 381V. If the configuration were switched to a delta connection, the line voltage would equal the phase voltage, thus also being 220V. The clarification confirms the relationship between phase and line voltages in different configurations.
tissue98
Very quick question PLEASE - Star Connection!
i'm just working on some questions on power engineering and there's a question on star connections. the wording is a bit funny - wondering if can get some clarification please.
"a three phase load is composed of three impedances of 10+5j. it is connected to a supply composed of three voltage sources of 220V. The three sources and three impedances are connected in star"
i am then asked to state the magnitude of the line voltage. I am confused about the wording - does it mean that the phase voltage is 220V (if there were three separate sources, this would be the case) or that the line voltage is 220V?
thanks for your help
i thought that the phase voltage would be 220 and so line voltage 220root3. is this correct?
since it specifically says that the voltage sources on the supply end are 220V and since it is star connected, the 220v refers to phase voltage. LL voltage would be 220root(3) as you thought.
if the sources are switched to delta, would the line voltage be 220?
since phase voltage = line voltage for delta connectio
yes.
