Vibration problem given Force,length and mass
  • Thread starter Thread starter Equilibrium
    Mass Vibration
5 replies · 2K views
Equilibrium
A flexible wire 80 cm long has a mass of 0.40g. It is stretched across stops on a sonometer that are 50cm apart by a force of 500N. The wire may vibrate at the following frequencies except one. WHich one?
a. 4000vib/s
b. 1000 vib/s
c. 3000 vib / s
d. 1500 vib/s
searched google for formula but none so far
no formula in my notes.
probably this one
[itex]a = -\frac{k}{m}s[/itex]
s = displacement
m = mass
k = spring constant
a = acceleration
or this one
[itex]T=2\pi\sqrt{\frac{m}{k}}[/itex]
T = period
m = mass
k = constant
i don't know
can you help me start?
You've written down the equations for simple harmonic motion. But I don't think that is what the question is about. If you look up a sonometer on google, it looks very much like the situation of standing waves on a string. (since it is fixed at two ends). So I think you should be using the equations for standing waves on a string.
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/string.htmli see now but the answer is not given in the multiple choice
[tex]f=\frac{v}{\lambda}[/tex]
[tex]f=\frac{v}{2L}\mbox{ since }L=\frac{\lambda}{2}[/tex]
[tex]v=\sqrt{\frac{T}{\rho}}=\sqrt{\frac{T}{\frac{m}{L}}}[/tex]
[tex]f=\frac{1}{2L}\sqrt{\frac{T}{\frac{m}{L}}}[/tex]
[tex]f=625Hz=625vib/s[/tex]
the question might be a typo or is it not?
I think you might be using incorrect values for L or m. The entire wire is 80cm, with mass 0.4g. But only 50cm of that wire is within the sonometer. So what should you use for L and m in the equation?
i see, so [tex]\rho=\frac{m}{L_{string}}[/tex] L_string = 80cm is different from
the length of the string apart which is the wavelength/2 = 50cm
1000vib/s
thanks
