Vibrational frequency of diatomic molecule
bull0sees
Using specific heat data for a nitrogen molecule, estimate then vibrational frequency of the diatomic molecule
C= 3N_a k = 3R
unable to attempt a solution
This question interests me. However I am no help with the solution. I would love if someone could answer this question
thank you for your input shamone. I would also love to find out the answer
I am surprised no one has answered. It looks like a straightforward answer but I just cannot come up with a solution, i wish i was smarter
C= 3N_a k = 3R
You could start by treating the diatomic molecule as two masses joined by a spring with a certain spring constant. (this may be correct only for small vibrations). You can express the frequency of vibration using the "spring constant", which is a function of the bond strength, and the mass of the N atom. The trick is to find the "spring constant" from the specific heat. I'll have to think about that one.
AM
I think I understand the problem. The N2 molecule acts as a harmonic oscillator at a frequency determined by the strength of the bond between the two N atoms and the mass of the N atom. But due to quantum effects, it cannot vibrate at any energy. Its modes of vibration are quantized:
E_{vib} = (n + 1/2)h\nu
At low energies (low temperature < 500K) the energy of vibration is h\nu/2 (n=0). The addition of thermal energy is not sufficient to allow many molecules to reach the next energy level (n=1) which is 3h\nu/2 (ie the number of molecules in the Boltzmann distribution for that temperature with that amount of energy).
However, as T increases the number of molecules able to acquire additional vibrational energy ie. to jump from h\nu/2 \text{ to } 3h\nu/2 increases so the specific heat starts increasing. At about 6000 K the specific heat, Cv reaches 3.5R. This means that the addition of any amount of thermal energy adds vibrational energy to the molecules which, I think, means many of the higher n levels are excited.
That should help you figure out the frequency \nu. From that you could figure out the force holding the atoms together, too.
AM
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
