Why is D'Alembert's Principle stated in terms of virtual displacements?
  • Thread starter Thread starter debasish panda
    Virtual
D'Alembert's Principle is expressed in terms of virtual displacements to focus solely on active forces, which are responsible for the motion of a system, while ignoring constraint forces that restrict movement. Virtual displacements refer to hypothetical changes in position that adhere to the system's constraints, making it easier to analyze dynamics without the complexities introduced by actual displacements. This simplification allows for a clearer understanding of how forces interact within the constraints of a system. The concept is foundational in mechanics and becomes more evident when studying Lagrangian mechanics. Understanding virtual displacements is crucial for solving problems involving constrained motion effectively.
debasish panda
  1. Why is the D'Alembert's Principle
    ∑i(Fi−miai)⋅δri=0
    stated in terms of "virtual" displacements instead of actual displacements?
    what does the 'virtual displacement' really means and what is its physical significance??
    ∑i(Fi−miai)⋅δri=0
The concept of virtual displacement is not immediate so you have to study it well in suitable texts/documents.
Here I want to give just a very simple example, which doesn't want to be comprehensive at all, but is useful (I think) to have at least some idea of the concept.
There is a point mass m which can move frictionless along an horizontal bar, in the direction x. The bar, which is the constraint for the point mass, can move vertically along direction y. So, the actual displacement of the point mass is along x and along y: dr = (dx,dy).
In this case the virtual displacement, instead, is the one only referred to the constraint: δr = (dx,0).
lightarrow
Likes debasish panda
    ∑i(Fi−miai)⋅δri=0
Because in this way only active forces can be considered. Active forces are those forces which doesn't arise in order to make the particle follow the constraints (these last are constraint forces). In the simple example I made in my previous post, active forces are those which make the particle move along the bar (horizontal forces) while constraint forces are those directed vertically, which prevent the mass point to escape the bar. Usually the constraint is still, or it moves in a specific, given way, so the problem is much simpler to solve if it's focalized in finding how the points move in virtual displacement only. But there are also theoretical reasons to focalize on those displacements only, which will be more clear whe you will study lagrangian mechanics.
lightarrow
Doc Al said:
lightarrow
thnx bro...
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
