What is the role of viscous friction in the drag force on a moving sphere?
  • Thread starter Thread starter IPhO' 2008
    Friction viscous
The drag force on a moving sphere in a liquid is described by Stoke's law, which states that the force is equal to 6πηrv, where η is the fluid's dynamic viscosity. This drag force results from the continuous collisions between the fluid molecules and the sphere, which collectively exert a force on it. At low Reynolds numbers, viscous drag is significant, and the drag force is proportional to velocity (v), while at higher Reynolds numbers, it can be proportional to the square of the velocity (v²). The distinction between these two behaviors depends on the fluid's viscosity and the flow regime around the sphere. Ultimately, the drag force is a result of fluid molecules impacting the moving sphere.
IPhO' 2008
When a sphere radius r has a velocity v in a liquid .It will has a drag force exerted on the sphere. The drag force is equal to 6\pi\etarv (Stoke's law)
where \eta is the fluid's dynamic viscosity
Where the drag force comes from ? How does this force occur?
Molecules in the fluid are constantly colliding with the sphere. The fluid molecules exert a force on the sphere via these collisions, and collectively these collisions result in the drag force.
The drag force from the colliding with the molecules of the fluid is equal to
\rho\pir2v2
This formula come from F\Deltat = m(v-u).
so, F \alpha v2.
but from Stoke's law F \alpha v.
\rho is the density of fluid.
viscous drag--or friction, proportional to velocity is the drag due to laminar flow around the object. It's not typical that a sphere will experience viscous drag but only at low renyolds numbers.
\rho\pir2v2
so, F \alpha v2.
That is true when collisions among the fluid molecules may be neglected, i.e. the viscosity is small.
For significantly large viscosity, the collisions between fluid molecules modify the force expression. In that case the force is proportional to v rather than v2.
In both cases, the force arises from fluid molecules impacting upon the moving object.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
