Visibility of laser light in mist of water particles
The visibility of laser light in mist is due to the scattering of light by water particles. When mist or clouds are present, the laser beam is visible because the particles reflect the light towards the observer's eyes. In the absence of mist, there are no particles to scatter the light, making the beam invisible. This phenomenon highlights the importance of scattering in visual perception of light beams. Understanding this can clarify why laser beams are seen in certain conditions and not others.
stevenbarea
Hello, I'm quite intrigued as to why when a mist of water particles (clouds etc) is being shined by laser light, the laser beam is seen clearly, all throughout the mist, but if you take the mist off, the laser beam is no longer seen. What's the theory behind this?
Thanks a lot
From Steven
Science news on Phys.org
You can only see light when it hits your eyes, so unless there's something--like mist or dust--to reflect the light to your eyes, you won't see the beam.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
