Can I Visualize Mathematical Terms with Wolfram Alpha?
Visualizing mathematical concepts, particularly functions and their derivatives, can significantly enhance understanding. While software like Mathematica and Maple is commonly used for this purpose, they can be costly. University students may have access to these tools through their computer labs, depending on course enrollment. Wolfram Alpha is recommended as a free alternative that can provide visualizations of functions and their derivatives. Utilizing these resources can aid in grasping complex mathematical terms and concepts effectively.
mather
hello!
I think it would help a lot to visualize mathematical terms
I would like to see the graphs of various f(x), then their f'(x), their f''(x), in order to understand what derivatives mean
example:
http://en.wikipedia.org/wiki/File:Graph_of_sliding_derivative_line.gif
same with differential equations, geometrical terms, probability terms, etc
is there a website that actually visualizes all these?
thanks!
Mathematics news on Phys.org
Hey mather.
Typically you do this kind of thing in something like Mathematica or Maple but these programs are expensive. If you are a university student though, you should see if one of your computer labs has a copy for you to use (you may have to be enrolled in a particular course to gain access to it though).
You should check out this and read how to get multiple output for your functions and derivatives:
http://www.wolframalpha.com/
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
