jegues said:
This makes me want to write the following voltage for V1',
[tex]V_{1} = V_{s} - V_{2}^{'}[/tex]
Because these are the voltages across the two endpoints or nodes of our element, and one branches down to connect to ground. It feels sort of intuitive but I'm still not entirely convinced it's correct.(We determined it wasn't previously)
I might still be a little confused but maybe once I see how V1' is determined I'll have a better feel of what's going on.
I see what you are trying to do, so let me explain further. Let's call the node that has been labelled V1', "node 1." The potential difference between node 1 and ground is V1' volts. In other words, if I take a voltmeter and touch one lead to node 1 and the other lead to ground, the voltmeter should read V1' volts.
Now, my claim is that this potential difference between node 1 and ground is equal to Vs. If that's true, then when I "travel" from ground to node 1, no matter what route I take through the circuit, I should gain an electric potential of Vs volts. How can I travel from ground to node 1? There are two possible routes. I could go through the branch that has the voltage source. If I do so, then clearly I WILL gain an electric potential of Vs volts, since I have moved across the voltage source. This serves to illustrate that the difference in potential between node 1 and ground is equal to the difference in electric potential between the terminals of the source (since the + terminal is connected to node 1 and the - terminal is connected to ground).
The second route I could take between ground and node 1 is across the branch with the two resistors R1 and R2 in it. When I move across this branch, I gain an electric potential equal to V
R2 + V
R1, where V
R2 is the voltage across R2, and V
R1 is the voltage across R1. Agreed? We know what these voltages across the resistors are:
[tex]V_{R2} = V_2^\prime - 0[/tex]
[tex]V_{R1} = V_1^\prime - V_2^\prime[/tex]
Agreed?
Therefore, the total electric potential I gain by going from ground to node 1 by traveling across the two resistors is just:
[tex]V_{R1} + V_{R2} = (V_1^\prime - V_2^\prime) + (V_2^\prime) = V_1^\prime[/tex]
So in summary, going across the branch with the source in it, I gain an electric potential of Vs. Going across the branch with the two resistors in it, I gain an electric potential of V
R1 + V
R2 = V1'. Since both routes involve traveling between the same two points, the potential difference must be the same for both routes, meaning that it must be true that:
[tex]V_s = V_{R1} + V_{R2} = V_1^\prime[/tex]
Do you see why this equation is right and the one you wrote down is not?
