Voltage multiplication using a battery
The discussion revolves around the challenge of obtaining 1000 VDC from a 9 VDC battery for charging capacitors in a coilgun application. Suggestions include using a Hartley oscillator or a Wimshurst machine, both of which can generate high voltage without converting to AC. The user expresses a preference for DC solutions due to space and weight constraints, dismissing charge pumps as impractical. Concerns about safety are acknowledged, but the user claims to have experience with high voltage. The conversation concludes with a sense of frustration from some participants regarding the project's nature.
alpine2beach
Okay, so before when I asked a question about voltage multiplication, I was recommended a charge pump. But now I realize that creating a charge pump to get the voltage I want would be rather ridiculous. So, here is my problem: I need to get 1000vdc from a 9vdc battery, but I'm not entirely sure how to do this conveniently (well, more conveniently than a charge pump that is). Have any suggestions?
Note: I don't want to convert to AC, otherwise, I wouldn't be asking this question.
What is the application? What kind of potential safety issues could you identify in this project for us?
I suggested looking at charge pumps when I did not know your source or target.
I can't imagine why you don't want to use a step up transfomer. A 9v battery can readily be persuaded to yield 500 to 1500 volts with a Hartley oscillator configuration, which is very simple. This is how many insulation testers work.
But, since you eschew such methods, try a Wimshurst machine. You will not then need a battery at all, just a bit of muscle power.
Lol, I knew I would be asked that. The application is for charging capacitors in a series, which are being used to power a coilgun. The potential safety issues aren't really an issue, as I have dealt with high voltage before, and know the safety precautions that I must take.
I guess I wasn't very specific on my first question. Anyways, I need to charge capacitors in a series. I need the DC because that would require a inverter, a transformer, and a bridge rectifier, and I am rather limited on space and weight. So to combat this, I thought that a DC to DC converter would be a much better alternative. A whimshurst machine would make a good alternative, although the same issue with the space turns up.
i don't know what is a whimshurst
but take a look at how the flash unit works in a throwaway disposable camera.
they turn 1.5 vdc into 400 vdc
using a "flyback" converter
how fast do you want to charge the cap?
local photolab folks at grocery or drugstore will probably give you a grocery sack of old disposable cameras- put 9v to one and see what it'll do.
But be careful, that photoflash capacitor in the camera will probably be charged and it's easy to get a surprisingly vigorous shock. Discharge it before you get very far nto disassembly..
I am glad I'm not helping someone with this attitude power a coilgun.
I retire from this thread, mods please feel free to delete my contributions (if any) so far.
Yeah, wanting to make a highly portable railgun in high school. I think this thread is done.
