Voltage of cylinder of radius R
The discussion revolves around calculating the electric field and voltage associated with a long solid cylinder that has a uniform volume charge density and linear charge density. The specific problem involves determining the electric field at various radial distances from the axis of the cylinder and calculating the voltage at specified locations, with a reference point set at a distance of 3R.
  • Participants discuss the application of Gauss's law to find electric fields both inside and outside the cylinder. There is an exploration of integrating the electric field to find voltage, with questions about the setup of integrals and the correct bounds for integration.
Some participants are attempting to clarify the integration process for calculating voltage, particularly at r = 0 and r = R. There is acknowledgment of potential confusion regarding the use of different electric field equations depending on the radial distance. Guidance has been offered regarding the need to consider both integrals when calculating voltage differences.
Participants express uncertainty about the correct setup for integrals and the implications of setting V=0 at r=3R. There are indications of conflicting results from different integration approaches, and some participants question the assumptions made in their calculations.
TwinCamGTS
ε
A very long solid cylinder of radius R = 6 cm has:
-uniform volume charge density ρ = +7 µC/m3.
-linear charge density λ = 7.9168E-8 C/m
Outside: What is the electric field at a radial distance of 7 cm from the axis of the cylinder?
Inside: What is the electric field at a radial distance of 5 cm from the axis of the cylinder?
Voltage: Setting V=0 at r=3R, find the voltage at the following locations:
V (r = 0)
V (r = R/2)
V (r = R)
V (r = 2R)
V (r = 4R)
using gauss law to find the electric field inside and outside the cylinder
inside the cylinder E = ( ρ*r )/(2*εo)
outside the cylinder E = ( λ )/(2*∏*r*εo)
Voltage is just integration of E, so V=-∫Edr
I find the electric field from the axis 0m to 0.07m using E = ( λ )/(2*∏*r*εo), i got 20338.948 N/C
I find the electric field from the axis 0m to 0.05m using E = ( ρ*r )/(2*εo), i got 19773.9484 N/C
The problem i have is to find the voltage from the asked distance to distance r=3R
we set V at 3R = 0.
i do the integration on E = ( ρ*r )/(2*εo) from r=0 to r=R to find the Voltage inside the cylinder
then do integration on E = ( λ )/(2*∏*r*εo) from r=R to r=3R to find the voltage outside the cylinder.
when it ask find the voltage at r=0, it means that i have to find the ΔV, which is from
V(r=0) to v(r=3R), then i do separate integral on that two different E equation, then add them up. Since V at r=3R is 0, then i pretty much ignored it during the integration. but i got it wrong. how am i supposed to do this. i have try many method and i think this is the correctway to do it. can someone help me out or explaining it to me? Thank you for your time and reply
For finding the potential at r = 0, you're right in having to add up the two integrals, one from r = 3R to r = R, then another from r = R to r = 0, but in your work there's only one. What happened to the other?
yeah, that's what i thought but the webassign said my answer is wrong, so i wonder what is the way to do it then?
so you say the method I am doing it is correct isn't it?
Or is be because the equation that i use is wrong?
when r=R, do i use equation of r gauss < R cylinder or r gauss > R cylinder?
if that is the way to do it, then might be the way i setting up the equation for the integral is wrong.
what do you thnk?
Yes, that method should be correct. Think about it like this:
$$\Delta V = V(r) - V(3R)$$
So this means that
$$V(r) = V(3R) + \Delta V$$
You know that V(3R) = 0, and also that you start integrating from 3R. So say to find the potential at r = 0:
$$V(r = 0) = 0 - \int^{R}_{3R}E_{outside}dr - \int^{0}_{R}E_{inside}dr$$
I think that's what you were doing -- you may have been a little off in the bounds or what field to use perhaps. And when r = R, you don't really pick between the fields -- R is when the field changes, so it's more that you switch the fields between the two integrals.
i don't know what to do.
I just do the easiest thing first, which is find the voltage V at r=R
based on the integration, i have 2 answers.
either 711.864 (integrated from r=0 to r=R) or 4005.527 (integrated from r=3R to r=R)
i put down either answer, and its wrong...
i find out that its weird, based on the graph of the voltage over radius,
the voltage from r=0 to r=R should be greater than from r=R to r=3R.
but based on the integral value, its the opposite.
Okay, so you evaluated both integrals, correct? But the answer isn't either of those -- look at the expression I posted. Those integrals are added together, right? Also, talking about the voltage at R is misleading -- what that means is the potential with respect to zero (V(3R)), so only the value of V(R) - V(3R) is meaningful. V(0) - V(R) means the potential difference between 0 and R, but says nothing about the potential at R.
I finally got it right. Apparently i was stupid to cross out the value during the integration just because they set the V=0 at r=3R. so i ended up get everything wrong.
thank you for your help :D
i appreaciate it
12K
