Voltage would a 737. microfarad capacitor
  • Thread starter Thread starter xpack
    Capacitor Voltage
To determine the voltage across a 737 microfarad capacitor charged by a 5.0 mA current for 2.0 seconds, the fundamental capacitor equation Q=CV is essential. The charge (Q) accumulated in the capacitor can be calculated as Q = I × t, which equals 5 mA × 2 s, resulting in 10 mC. Using the capacitance value, the voltage (V) can be found by rearranging the equation to V = Q/C, leading to V = 10 mC / 737 µF. This results in a voltage of approximately 13.6 volts across the capacitor after the charging period. Understanding these relationships is crucial for solving capacitor-related problems effectively.
xpack
To what voltage would a 737. microfarad capacitor be charged by a 5.0. mA current lasting 2.0 seconds.
t=R/C
T=Time
R=Resistance
C=Capacitance
Q=CV
R=TC
2x.000737=.001474
Then I'm stuck at this point
Can anyone explain this please?
Hi xpack! :smile:
From the PF Library on capacitor (put V0 = 0 :wink:) …
Inverse exponential rate of charging:
A capacitor does not charge or discharge instantly.
When a steady voltage V_1 is first applied, through a circuit of resistance R, to a capacitor across which there is already a voltage V_0, both the charging current I in the circuit and the voltage difference V_1\,-\,V change exponentially, with a parameter -1/CR:
I(t) = \frac{V_1\,-\,V_0}{R}\,e^{-\frac{1}{CR}\,t}
V_1\ -\ V(t) = (V_1\,-\,V_0)\,e^{-\frac{1}{CR}\,t}
So the current becomes effectively zero, and the voltage across the capacitor becomes effectively V_1, after a time proportional to CR.
I'm not sure I understand
That's because tiny-tim was answering a different question (assumption of voltage source and equalization of capacitor voltage).
Instead, use the capacitor equation: Q=CV
(Yes, you'll need to do some rearranging, and use a formula for current--c'mon, we can't do all the work for you!)
Well I've never seen a problem like this. Our teacher gives very poor lectures and then assigns homework another teacher created so I really don't know anything. I'd rather yall not give me the answer and instead explain it, so that way for future reference I know how to work it myself.
I suspect that this is THE standard capacitor question (since I'd seen it in both my intro electromagnetics course, as well as my intro circuit analysis course). It's designed to show you that a capacitor is a device that stores charge, and that current is just the flow of charge.
First off, the fundamental capacitor equation Q=CV means that the voltage across a capacitor is related to the charge accumulated by the capacitor, by the (inverse of) the capacitance.
I'll use an analogy here. Imagine you have some flowing water, 0.1 L/s. Now you have a beaker with a cross-section of 100 cm^2. In 2 seconds, how high is the water in the beaker?
Now, current is just a flow of electrons i=\frac{Q}{t}. With a flow of 5 mA (or 5 mC/s), and 2 seconds of flow, how many coloumbs of electrons would accumulate in the capacitor, and consequently, how much voltage would you measure across this capacitor?
