Volume of a partially full fuel tank
  • Thread starter Thread starter Tregg Smith
    Fuel Tank Volume
The discussion focuses on calculating the volume of fuel in a partially filled cylindrical tank, specifically when the tank is lying on its side. The tank's dimensions are 6 feet in length and 4 feet in diameter, leading to a total volume of approximately 560 gallons when full. The user seeks to determine the volume of fuel at specific heights, such as 6 inches and 1 foot from the bottom, and whether these volumes can be calculated using simple fractions of the total capacity. Integral calculus is necessary for accurate volume calculations, as the volume does not decrease linearly with height due to the circular cross-section of the tank. The conversation emphasizes the complexity of the problem and the need for precise mathematical methods to find the desired fuel volume.
Tregg Smith
Finding the volume of a partially full cylindrical tank that lies on it's length. L=6', D=4"
pi r sq times L = cu ft when full. Convert to gallons 1 gal. =
.1336 cu. ft. (I think)
(pi r sq times L)/2 = when half full
How about when the fuel is one foot off the bottom? Is this simply (pi r sq times L)/4 ?
How about when the fuel is 10" off the bottom?
The volume of this tank is about 560 gal. which is way too much for the application. Diesel fuel goes bad after a year or two. Only 50 gallons are used each year. If you fill it then you throw out 500 gal. each year. The intake tube from the tank to the generator motor is 6" off the bottom of the tank. I want to know how many gallons to put in the tank that would allow 75 gallons or so to be available-so you would calculate how many gallons are there at 6" then add 75 gallons. That's why I ask is this just a straight line problem where one foot off the bottom equals one fourth of the tanks total capacity etc.? If so then 6" being 1/8 total would be... 560gal/8=70gallons + another 75 gallons=145gal. :rolleyes: To put it another way does the area of a circle decrease linearly as a line touching two points on the circle gets shorter?
No, you cannot use the formula for volume of a cylinder for part of a cylinder. In fact, this problem is not really "pre-calculus", it is a standard problem in integral calculus.
Imagine the fuel in the cylinder divided into "layers" of different heights. Each layer is a rectangle. The area of the rectangle is "length times width". We can take the length of each rectangle to be the same as the length of the cylinder: h. The width, however, varies with height. If we take x as the height and take x= 0 at the center of the circular end we can write the equation of the circle to be x^2+ y^2= r^2 so that y= \pm\sqrt{r^2- x^2}. The width of the rectangular layer is from "circle to circle"- twice y= 2\sqrt{r^2- x^2}.
The area of each rectangle, then, is "length times width"= 2h\sqrt{r^2- x^2}. If we take the thickness of the layer to be the infinitesmal dx, the volume is given by 2h\sqrt{r^2- x^2}dx. The entire volume is the integral from the bottom, at x= -r, to the height of the fuel:
V= 2h\int_{-r}^{2r} \sqrt{r^2- x^2}dx
Thx for your help. I don't quite see all of what you're saying-it's been 30 years since I had calculus. In the mean time can you give me the answer to how many gallons are at the six inch level off the tank bottom(before it starts sucking water into the engine-it's dangerously close) then I'll add 75 gal. run time to that.
The area of each rectangle, then, is "length times width"= 2x\sqrt{r^2- x^2}. If we take the thickness of the layer to be the infinitesmal dx, the volume is given by 2x\sqrt{r^2- x^2}dx. The entire volume is the integral from the bottom, at x= -r, to the height of the fuel:
V= \int_{-r}^h 2x\sqrt{r^2- x^2}dx
It is not difficult to integrate that- use the substitution u= r^2- x^2.
There was an error in what I wrote before: I had 2x\sqrt{r^2- x^2} when it should have been 2h\sqrt{r^2- x^2}- the "h" is the length of the cylinder.
You posted this in the homework section and it is the policy of this forum to not give answers to homework. Are you saying it is not homework?
With h= 6' and D= 4' (you had 4" but surely that's not right? Not if you are asking about the volume when the fuel level is at 6"!), the radius is 2' and 6" above the bottom is 1/2 '. The volume of fuel 6 inches above the bottom is
2h\int_{-2}^{-3/2}\sqrt{4- x^2}dx
The substitution x= 2sin(t) should simplify that.
:smile: No this isn't homework-I'm 62. I think it says homework or homework like questions. I don't understand the symbols. I would just like the answer as to how many gallons are at the 6" level. The diameter is four feet, length six feet.
The substitution x= 2sin(t) should simplify that.[/QUOTE]
If you let x= 2 sin(t) the 4- 4 sin^2(t)= 4(1- sin^2(t))= 4cos^2(t) so that \sqrt{4- x^2}= \sqrt{4cos^2(t)}= 2 cos(t). Also dx= 2 cos(t) dt so that \sqrt{4- x^2} dx= 4 cos^2(t) dt
When x= -2= 2sin(t), sin(t)= -1 and t= -\pi/2. When x= 3/2= 2 sin(t), sin(t)= 3/4 so that t= arcsin(3/4)
\int_{-2}^{3/2}\sqrt{4- x^2}dx= 4\int_{-\pi/2}^{arcsin(3/4)} cos^2(t)dt
= 2\int_{-\pi/2}^{arcsin(3/4)} 1+ cos(t) dt= 2\left(arcsin(3/4)+ \pi/4- 3/4+ \sqrt{2}/2\right)
