Volume of block given underwater and land weight
The problem involves calculating the volume of a metal block that weighs 9N in air and 7N in water, indicating a buoyancy scenario. The difference in weight, 2N, corresponds to the weight of the water displaced by the block. Using the density of water, the volume can be determined from this weight difference. The correct volume of the block is calculated to be 200 cm³. This solution effectively applies principles of buoyancy and density to find the answer.
test2morrow
A block of metal weighs 9N in air and 7N in water. What is volume of block?
correct answer: 200cm^3
w=mg
d=m/v
I figured out that it has mass of 0.9kg on land...which may or may not be helpful.
You know the difference in weights of the block when in different mediums. This is a buoyancy problem. The difference in weights is equal to the weight of water displaced by the block. If you use the density of water with the weight of water displaced you'll get the volume of the block.
thanks!
