Water bath with controlled temperature
  • Thread starter Thread starter nellierd
    Temperature Water
To maintain a constant water temperature for an experiment at home, using an aquarium heater is suggested, especially for smaller volumes like 1000 ml. The discussion emphasizes the importance of knowing the specific temperature range required and the accuracy of the thermometer used for measurement. Participants inquire about the temperature limits and recommend monitoring the water closely to ensure stability. Maintaining the temperature without adding more hot water is a key concern. Overall, careful setup and monitoring can help achieve the desired temperature control for the experiment.
nellierd
Hi,
I want to conduct an experiment where I want to maintain water temperature at a particular value. Its an experiment for a project and I have to do it at home. Is there any ideas of how I can keep the temperature constant(may be for 45 min). I have to do the experiment at temperatures above room temperature and I have to figure out how to do it. I also don't want to increase the amount of water (like mixing in more hot water, if temperature drops) Any ideas, please help. Thanks in advance. I would be doing the experiment with 1000 ml of water.
Science news on Phys.org
nellierd said:
Hi,
That's not too much water, so an aquarium heater might work for you, assuming you don't need the water too hot.
How tight a limit do you have on the temperature? How accurate is the thermometer that you are going to measure the temperature with?
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
