Effects of New Solid Sphere on Water Level
In summary, when a small solid sphere of mass M0, radius R0, and density ρ0 is replaced by a new solid sphere with different mass, radius, and density, the possible effects on the water level L in a bowl of water are as follows: with a new sphere having less mass and same density, the water level will fall; with a new sphere having same density and larger radius, the water level will rise; with a new sphere having same mass and larger radius, the water level may rise or remain unchanged depending on the density; with a new sphere having same mass and radius, the water level will fall if the density increases; with a new sphere having same mass and density greater than ρ0, the
gummybeargirl
A small solid sphere of mass M0, of radius R0, and of uniform density ρ0 is placed in a large bowl containing water. It floats and the level of the water in the dish is L. Given the information below, determine the possible effects on the water level L, (R-Rises, F-Falls, U-Unchanged), when that sphere is replaced by a new solid sphere of uniform density.
1) The new sphere has mass M < M0 and density ρ = ρ0
2) The new sphere has density ρ = ρ0 and radius R > R0
3) The new sphere has mass M = M0 and radius R > R0
4) The new sphere has radius R = R0 and mass M < M0
5) The new sphere has mass M = M0 and density ρ > ρ0
6) The new sphere has density ρ < ρ0 and radius R > R0
2. The attempt at a solution
1) F (less mass means displaces less water)
2) R (larger radius displaces more water)
3) R or U (if the density is lower it would be unchanged, but it could rise)
4) F or U (it would displace more less water, unless the density increased)
5) R (it would sink increasing water level)
6) R or F or U (it could sink or float or not change it at all)
Answer is correct, but I think your explanation is unsatisfactory.
The density IS lower (same mass, more volume) but why could that mean it's unchanged?
The density is necessarily decreased (same volume, less mass)
Would it sink? ρ0 is not the density of water
Yes, this is the only one with an uncertain answer (it depends on how much R/ρ are changed)
What is a solid sphere and how does it affect the water level?
A solid sphere is a three-dimensional object with a round shape that is completely filled with a material, such as metal or plastic. When a solid sphere is placed in a container of water, it displaces an amount of water equal to its volume. This displacement causes the water level to rise.
Can the size of the solid sphere affect the water level?
Yes, the size of the solid sphere will directly impact the amount of water it displaces and therefore, the change in water level. A larger solid sphere will displace more water and cause a greater rise in the water level compared to a smaller solid sphere.
Does the material of the solid sphere affect the water level?
Yes, the material of the solid sphere can have an impact on the water level. A more dense material will displace more water and cause a greater rise in the water level compared to a less dense material. Additionally, the shape and surface area of the solid sphere can also affect the amount of water displaced and the resulting change in water level.
Are there any other factors that can influence the change in water level caused by a solid sphere?
Yes, there are other factors that can affect the change in water level. These include the temperature of the water, the pressure of the water, and the presence of other objects in the water. These factors can impact the density and volume of the water, which in turn, can affect the displacement caused by the solid sphere.
How can the effects of a solid sphere on water level be measured and calculated?
The effects of a solid sphere on water level can be measured and calculated by using the principles of buoyancy and Archimedes' principle. The volume of the solid sphere can be determined by measuring its dimensions, and the amount of water displaced can be measured using a graduated cylinder or other measuring device. By using these measurements and calculations, the change in water level caused by the solid sphere can be accurately determined.
