Work Done to Move Water & Fold Iron Chain
To calculate the work done to move water from a cylinder tank to a height of 4 meters, the potential energy must be considered at varying heights, leading to the use of the equation mgh with a reference height established. For the iron chain, the problem involves folding it, requiring the calculation of work done to lift half of the chain, which weighs 50 kg, to a height of 5 meters. Initial calculations incorrectly assumed the mass as 60 kg, leading to confusion. The correct approach confirms that only half the chain's weight is relevant for the work calculation. Ultimately, the work done for both scenarios can be computed using the principles of potential energy.
Biker
Member warned not to place multiple questions in the same thread.
A cylinder water tank its radius 0.5 m, its height is 2 m and it is full of water. Determine the work done to move the water to a height of 4 meters above the height of the cylinder water tank.
Another question related to it is:
An uniform iron chain its length is 10 m and its mass is 10 kg for each meter. Calculate the amount of work done to fold it to the top.
Work = f *d
So at the first I thought that plug the casual mgh here because water's mass is not concentrated in a spot. It has different heights. So If the height of the cylinder is 2 meter then I can take the height of 1 meter as a reference. If I sum all the potential energy of the water it will be equal to zero (Since it cancels out). Now I assumed that It is on one level now with a potential energy of 0 and I calculated the work needed by getting the h first which is 1 + 4 = 5 Then using the equation mgh to get the work done.
Second question: Okay I am facing a problem here.
So I thought If I want to fold it (That is what I understood of the question and translated it) then I have to move one of its halves to the other. As it is uniform then I should cut it to 5 meters pieces each of them has a mass of 50 kg. Then use the same approach that I used in question 1. To make a level where the potential energy is 0 which is x = 2.5 and take it as my reference point. Then I want it to move upward to 7.5 m. Get the d of these 7.5-2.5 = 5 m
Plug it into the work equation = mgh but my answer is wrong. In my textbook it shows only the final answer without steps. So as I result I found that instead of 50 kg it used 60kg. So I guess I have something wrong here.
Edit: there is a much easier way to do it.
I believe you are correct. Half the chain (50kg) is being raised 5m.
Likes Biker
