Calculating the Cost of Heating Water for a 10 Minute Shower
  • Thread starter Thread starter kkcool
To calculate the cost of heating water for a 10-minute shower using natural gas, first determine the total water used, which is 100 liters. Next, calculate the heat required to raise the temperature of this water from 10°C to 45°C using the formula Q = mcΔT, where m is the mass of the water, c is the heat capacity, and ΔT is the temperature change. Convert the heat energy from joules to gigajoules to find out how much natural gas is needed, given the price of $9.00 per GJ. Finally, multiply the amount of gas needed by the price to find the total cost of heating the water for the shower. This method provides a clear approach to estimating the expense associated with hot water usage.
kkcool
If you have a 10 min shower using hot water at a rate of 10L/min, how many dollars does it cost to heat the water using natural gas if hte price of natural gas is $9.00 per GJ? Assume the T of the hot water is 45 C and the T of the cold water that needs to be heated is 10 C. Heat capacity of water = 4.184 J g^-1 C^-1, and density of water = 1.00 g/mL.
Any help will be greatly appreciated !
You must attempt to answer the question yourself before we can help you.
You need to use the template and show what you have done to solve the problem.
I don't even know how to begin to solve the problem. Can you give pointers on how to start?
Such questions are asked in some context - that is, there was a lecture on something and now you should use information from that lecture. Question can be solved in many ways, but most likely you are expected to use one of them - we have no idea which one, so our hints can be off. Basically you have to calculate how much water you use during shower, how much heat is needed for the temperature change, how much gas is needed to produce the heat, how much does the gas cost.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
