Sure, I can help explain this concept to you. Let's start by breaking down the information given. The wave equation is a mathematical equation that describes the behavior of waves, such as light or sound waves. It is commonly used in physics and engineering to study wave-like phenomena.
The given information states that both the initial function u(x,0) and the initial derivative Ut(x,0) are odd functions of x. An odd function is one in which the function values are symmetric about the origin, meaning that f(x)=-f(-x). In other words, if you were to reflect the graph of an odd function across the y-axis, it would look exactly the same.
Now, let's look at the general solution for the wave equation provided. It has two parts: the first part involves the initial function φ(x) and the second part involves the initial derivative ψ(x).
The first part (1/2)*[φ(x+ct)+φ(x-ct)] is a combination of two terms. The first term, φ(x+ct), represents the displacement of the wave at a point x+ct, while the second term, φ(x-ct), represents the displacement at a point x-ct. Since φ(x) is an odd function, both of these terms will be odd as well.
The second part (1/2c)*(integral ψ(s)ds, from x-ct to x+ct) involves the initial derivative ψ(x). Since ψ(x) is also an odd function, the integral over the range of x-ct to x+ct will be an odd function as well.
Putting these two parts together, we can see that the solution u(x,t) is a combination of two odd functions, which will result in an overall odd function. This means that for any value of t, the solution u(x,t) will still be an odd function of x.
In conclusion, the given information and the general solution for the wave equation show that if both the initial function and initial derivative are odd functions, then the solution to the wave equation will also be an odd function for all values of t. I hope this helps clarify the concept for you.
