Can a Convex Lens Converge a Tilted Wavefront?
A parallel beam of light with a varying speed from bottom to top creates a tilted wavefront when passed through a glass slab with a linearly increasing refractive index. This variation in speed causes the beam to bend, altering its direction and preventing it from remaining parallel to the x-axis. Consequently, a convex lens aligned along the x-axis may not effectively converge the rays at a single focus. The discussion also raises the possibility of interference effects due to path differences between rays, questioning whether a bright spot could appear on a screen above the focal plane. Ultimately, the behavior of the light is governed by Huygens' principle, which indicates that the direction of velocity is always perpendicular to the wavefront.
AdityaDev
If I have a parallel beam of light parallel to x-axis, with the speed of light varying from bottom to top. Let it decrease from bottom to top. (To get such a beam one can pass the beam through a glass slab normal to its surface, whose refractive index increases linearly from bottom to top). Now although the beam is still parallel to x-axis, the wavefront is tilted. Will a convex lens (principle axis along x) be able to converge the rays at focus? There exists a path difference between two successes ice rays. Hence shouldn't we consider interference? Will there be a bright spot on a screen kept at focal plane but above the focus?
Science news on Phys.org
If the speed of the wavefront varies, then the beam of light will bend and change direction as it travels, possibly converging or diverging as well. It will no longer be parallel to the X-axis.
Likes AdityaDev
Actual reason: From huygens principle, direction of velocity is perpendicular to wavefront. Hence direction changes.
  • · Replies 40 ·
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 66 ·
