eoghan
- 201
- 7
Hi all,
why a wave function has to be a continuous function?
Demystifier said:Wave function does NOT need to be continuous. The derivatives may be well defined even if it is not continuous (for example, consider the step-function). Note also that, by the Fourier theorem, a superposition of plane waves (which is a solution to the free Schrodinger equation) may represent a function which is not continuous at certain points.
ZapperZ said:Under what condition would the wavefunction not be continuous? I can see how the derivative may not be continuous, such as for a delta function barrier resulting in a derivative jump, but this isn't the question posted by the OP.
Zz.
jostpuur said:I didn't get into detail yet, but wouldn't this occur with some patological potentials? U(x)=\lambda \partial\delta(x) for example. I don't think that would be completely unphysical. An intuitive interpretation of that potential would be, that there is a sharp spike of a magnitude -\infty\lambda on the left side of the origo, and other spike of a magnitude \infty\lambda on the right side. That could represent some real situation.
ZapperZ said:But isn't this the delta function potential that I've mentioned at least twice in here? This results in a first derivative jump but not a discontinuous wavefunction, no?
Zz.
jostpuur said:Not really, it was supposed to be a derivative of a delta function. I though it could have solution like \psi(x)=((A-B)\theta(x)+B)e^{ipx/\hbar}, that would be discontinuous, but now when I checked that, I couldn't make it work. Perhaps my intuition was wrong.
ZapperZ said:Perhaps I don't understand the profile of your potential function. To me, "sharp spikes" in the potential means delta functions. Your infinite delta functions, if they are at particular positions, then would be the very same ones that I have described. But the "derivative" of delta function is not something that I'm familiar with. Is it even well-defined? Such function do have finite integral, but not first derivatives, no?
Zz.
jostpuur said:Actually I have never seen derivatives of delta functions used in any reliable sources, but I did convince myself that they should be quite OK objects.If you approximate delta function with some finite peak g(x), then its' derivative has a positive peak on the left side of the origo and a negative peak on the right side (I said this the wrong way in the previous post), but you cannot write \partial\delta(x) as sum of two other delta functions, because the peaks are infinitesimally close to the origo. The integral \int g(x)f(x) dx then is something like \approx A(-f(\Delta x) + f(-\Delta x)) for some small \Delta x, and multiplied with some constant A whose value is not obvious, but it seems reasonable to assume it could be -\partial f(0). That it is what it becomes when you use integration by parts like this \int (\partial\delta(x))f(x)dx = -\int \delta(x)\partial f(x)dx.
Having made these remarks myself, I've come to believe, that \partial\delta(x) is okey. I don't know about rigorous distribution theory.
See http://mathworld.wolfram.com/GeneralizedFunction.html . By the way, there are references there to books by Vladimirov and Gel'fand/Shilov .jambaugh said:WRT the delta-function, I don't think that "functional" is the right term.
Rather the integral which utilizes the delta function is a functional. Functional = a "function" with domain within a space of functions. Example the action of classical Lagrangian mechanics is a "function" of the particle path and so is a functional.
The proper term for the delta function is that it is a "test function" or a "distribution". It is a distribution in the sense that it acts as a measure on the real interval weighing one point (the origin) over all others.
jostpuur said:That notation looks strange. I've got used to \delta^{(n)}(x-x') meaning delta-function in n dimension. Did that n now mean n:th derivative? If so, shouldn't there have been also a factor (-1)^{n}?
akhmeteli said:See http://mathworld.wolfram.com/GeneralizedFunction.html . By the way, there are references there to books by Vladimirov and Gel'fand/Shilov .
As I said, "generalized functions" is just another name of "distributions", such as the delta-function.
Let me emphasize the following phrase from Mathworld: "Generalized functions are defined as continuous linear functionals over a space of infinitely differentiable functions such that all continuous functions have derivatives which are themselves generalized functions." So they are typically DEFINED as functionals. Thus, distributions are functionals by definition. Of course, you may define distributions many other ways. But this is one of generally accepted ways to define distributions. You may say, following Wikipedia, that mathematicians identify distributions with functionals. Whether we, physicists, like it or not![]()
What I was trying to emphasize, they are not just defined VIA functionals, they are typically defined AS functionals, or, in other words, identified with functionals BY DEFINITION (nothing is sacred for those mathematiciansjambaugh said:Quite right, generalized functions aka test functions aka distributions are defined via functionals
