Particle Moving on a Straight Line: Where is it Likely to Be Found?
The discussion centers on determining where a particle moving in a straight line is likely to be found, using the wave function ψ(x)= (1+ix)/(1+ix^2). The participant initially calculated the derivative of the probability density and found critical points, including imaginary values, which were deemed irrelevant. Clarification was provided that the question likely seeks the expectation value of x or the maximum probability density, rather than stationary points. The probability density plot confirmed that the maxima occur at approximately x = 0.643 and x = -0.643. Ultimately, the conversation emphasizes the importance of distinguishing between maximum probability and expectation value in quantum mechanics.
roshan2004
A particle moving on a straight line is described by \psi(x)=\frac{1+ix}{1+ix^2}.
Where is the particle likely to be found?
I took the derivative of probability density with respect to x and equated it to 0. I got my answer to be x=0.643,-0.643,1.554i and -1.554i.
Please tell me whether I am right or wrong or are there any other methods to solve this problem or not?
There is no reason for the expectation value to be at a stationary point of the probability density.
You have to evaluate the integral <x> = ∫ψ*(x)xψ(x)dx = ∫xP(x)dx.
But the question is about maximum probability of finding the particle, isn't it?
"Where is the particle likely to be found" usually means that they want you to find the expectation value of x.
Unless the exact wording of the question was "where is the particle most likely to be found". Then you would find the x which maximises P(x).
So if the question is where the particle is most likely to be found, is my answer correct.
x is a real number, how did you get imaginary values?
By factorising
Now I finally got it, thanks dx
