How Do You Normalize a Wave Function and Verify Its Momentum Space?
Tales Roberto
Consider the wave packet \psi\left(x\right)=\Psi\left(x,t=0\right) given by \psi=Ce^{\frac{ip_{0}x}{h}-\frac{\left|x\right|}{2\Delta x} where C is a normalization constant:
(a) Normalize \psi\left(x\right) to unity
(b) Obtain the corresponding momentum space wave function \phi\left(p_{x}\right) and verify that it is normalized to unity according to: \int^{\infty}_{-\infty}\left|\phi\left(p_{x}\right)\right|^{2} dp_{x}=1
(c) Suggest a reasonable definition of the width \Delta p_{x} and show that \Delta x \Delta p_{x} \geq h
(a) is easy to solve and we find that C=\frac{1}{\sqrt{2\Delta x}} assuming that C is real. This way \psi=\frac{1}{\sqrt{2\Delta x}}e^{\frac{ip_{0}x}{h}-\frac{\left|x\right|}{2\Delta x}
I attempt to use Fourier Transform to calculate (b):
\phi\left(p_{x}\right)=\left(2\Pi h \right)^{-\frac{1}{2}} \int e^{\frac{-ip_{x}x}{h}} \psi dx
\phi\left(p_{x}\right)=\left(4\Pi h \right\Delta x)^{-\frac{1}{2}} \int e^{\frac{-i\left(p_{x}-p_{0}\right)x}{h}} e^{\frac{-\left|x\right|}{2\Delta x}} dx
\phi\left(p_{x}\right)=\left(4\Pi h \right\Delta x)^{-\frac{1}{2}} \left[\int_{0}^{\infty} e^{-\left(\frac{ip}{h}} + \frac{1}{2\Delta x}\right)x} dx + \int_{-\infty}^{0} e^{-\left(\frac{ip}{h} - \frac{1}{2\Delta x}\right)x} dx\right]
where p=p_{x} - p_{0}. To simplify let's write:
\beta_{1}=\left(\frac{ip}{h}} + \frac{1}{2\Delta x}\right) \beta_{2}=\left(\frac{ip}{h} - \frac{1}{2\Delta x}\right)
Then:
\phi\left(p_{x}\right)=\left(4\Pi h \right\Delta x)^{-\frac{1}{2}} \left[\int_{0}^{\infty} e^{-\beta_{1}x} dx + \int_{-\infty}^{0} e^{-\beta_{2}x} dx\right]
This integral does not converge since arguments are complex. My "feeling" is that my solution is completely wrong, please help!
are you sure those integrals don't converge?
I calculated the integral, however i anchieved a "weird" result. I think it was wrong, i expected an exp term. Here my result:
\phi\left(p_{x}\right)=-\left(4\Pi h \Delta x\right)^{-\frac{1}{2}}\left[\frac{1}{\frac{ip}{h}+\frac{1}{2\Delta x}}+\frac{1}{\frac{ip}{h}- \frac{1}{2\Delta x}} \right]
I have nothing to do with this, may wrong!
i haven't tried it in detail, but it looks reasonable to me... the exponentials disappear when you take the infinite limit
try simplifying, by putting it all over the same denominator, it at least makes sense in that it goes to zero for large |p|
now calculate the magnitude square (worth plotting) to get the momentum probability density function and check if its normalised...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
