Wave Generation from Point Sources: Interference Patterns and Radio Aerials
Wave generation from point sources creates directional interference patterns, particularly when sources are aligned and closely spaced. Antenna arrays can effectively control radiation patterns, with element spacing typically less than a wavelength. Impedance varies based on the arrangement of dipoles, with closer elements increasing impedance, necessitating careful feeding techniques to maintain power distribution. The discussion highlights the importance of phase alignment in achieving desired beam patterns, with parabolic reflectors being optimal for focused transmission. Overall, practical antenna design requires consideration of spacing, impedance, and the trade-offs between array complexity and performance.
poor mystic
Hi Everybody!
I have been wondering about wave generation from point sources, and interference.
I have noticed that if several point sources are sited in a line much more than one wavelength long, a very directional interference pattern develops. The closer the sources and the longer the line, the better the directionality.
Can radio aerials be set in such an array?
poor mystic said:
Hi Everybody!
Absolutely. Antenna arrays are commonly used for controlling directionality of the radiation pattern. The element spacings are generally less than a wavelength, though.
http://en.wikipedia.org/wiki/Antenna_array
http://www.google.com/images?hl=en&source=imghp&q="antenna+array"&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
Hi! and thank you for these replies.
I'd wondered about how you would drive such an array.
Say the aerial is made up of dipoles at some small spacing such as a tenth of a wavelength, how can I find impedance?
A dipole in free space will have an impedance of about 72 ohms if driven at the centre.
Two dipoles more than a half wavelength apart will also have impedances of about 72 ohms.
As you bring them close together and parallel to each other, and feed them in phase, their individual impedances will rise, approaching 144 ohms when they get close together.
To feed them, you could attach a half wavelength of any feedline to each one and then just put the other ends of the feedlines in parallel. This will give an impedance close to 72 ohms and each dipole would share the available power from a transmitter, in phase.
An excellent antenna simulator is Eznec which is available as a Demo (free) version. (www.eznec.com)
Takes a little bit of getting used to the operation of it, but it is easy to use after that.
Spacing the elements by only 1/10 lambda is not very good 'value'. The beamwidth is inversely related to the total 'aperture' of the array. 'Filling in' with lots of elements in a wide array can give a nice 'smooth' radiation pattern but is an expensive solution.
Input impedance can be very dependent upon the way the elements are driven, for a phased, directional, array. To get an idea of the best solution, it would be necessary to know the wavelength and application as it is a very practical subject, each frequency band having its own quirks and solutions.
Hi Guys, and thanks for looking at this
I have a set of ideas I'm pretty confident about but want to test anyway. These ideas are about wave superposition.
I noticed that a set of aerials, all in a line, closely spaced and transmitting in the same phase, ought work together to make a very tight beam.
I'd like to test the beam-forming idea, and I'm looking for an affordable experiment.
Radio at 400MHz or so sounds good.
I wondered whether a rectangular planar aerial could be driven from an edge (which might be like very many closely-spaced aerials), and whether a circular plane could be driven from the middle, similarly.
The answers I have received are encouraging! Thank you
Superposition works!
For a uniformly illuminated aperture you will end up with a sinx/x pattern - just what you would get from light through a single slit with no phase tilt across it.
Your idea of feeding a rectangular array will introduce a phase tilt across the aperture so will produce a different pattern. You need to excite every bit of the array in phase and this is not compatible with a simple feed arrangement. The transit times along the feed need to be considered. You would need a weird three dimensional shape of surface to achieve a constant path length from source to feed (a conic section probably). This is basically why a parabolic reflector works so well.
The only problem in realising some of these arrays is splitting the feed, introducing no phase errors and producing a reasonable match to a transmitter. Of course, in a simulation, that needn't worry you.
For good acuity, you can make do with a very sparse array of antennae but the radiation pattern of such an array is full of what can be embarrassing sidelobes. We're talking interferometry here, which is the poor man's version of a huge array.
The basic theory of the pattern of a finite number of point sources approaching the pattern of a uniform aperture is not too hard - you go from a summation to an integral. Loads of antenna theory books will tell you about it. Offhand, I can think of an excellent book by Jordan (published in the 50s, I think).
One way to achieve this is the cylindrical reflector.
You have a dipole at the focal point of a parabolic reflector. Like a dish, but only in two dimensions.
[PLAIN]http://dl.dropbox.com/u/4222062/cylindrical%20reflector.PNG
The spacing of the dipole from the reflector is such that all the reflected waves are in phase with each other as they leave the reflector.
This gives a very concentrated beam of energy, mostly in the same direction.
Did you get a copy of Eznec?
Hi and thanks for the interesting replies.
It's easy for me to forget that the wavefront from a parabola is in phase for some reason, and I had forgotten it.
The parabolic trough idea is good, especially since several could be placed along an axis at half-wavelength spacing for super-directivity. I don't think there is any lower limit to the size of the parabolic dish?
Thank you, I did get a copy of EZNEC Demo v. 5.0, which I have started to look at.
The wave from the dipole to the outer edges of the relector has to leave the reflector at the same time as the wave from the dipole to the inner parts of the reflector has traveled in space and is just passing the plane of the outer edges of the reflector.
That is distances A + B must equal distance C in the diagram below to keep the waves in phase across the transmitted wave.
[PLAIN]http://dl.dropbox.com/u/4222062/Parabolic%20reflector.PNG
Mark, continue on email if you want to get started on Eznec.
It doesn't cope with parabolic reflectors, though, especially the Demo version which is limited to 20 segments.
The beamwidth is about λ/width of aperture so there is no actual "limit" - it just depends what response you want
Though I may well be wrong, I had concluded that, within a broad range of designs, any parabolic dish is equivalent to any other.
I got this idea from noticing that a parabolic dish is not really the ideal solution to the problem of focusing waves by reflection. The ideal solution is an ellipse, if I may use this shorthand for 'the figure obtained by rotating an ellipse about its long axis'.
An ellipse is made by drawing an inelastic cord tight between 2 points and drawing a curve. The points are the foci, and the tangent at every point of the curve is such as to reflect an image of each focus onto the other.
The distance between the foci, including the reflected part of the hop, is equal no matter which part of the ellipse the reflection is made from.
In the case of a manufactured parabolic dish, the calculation for the ellipse has been simplified and the curve is a little different, but in that it works at all it is an approximation to the ellipse, and probably quite a good one, designed to be less than a mm or so different from the ellipse.
If you want a parallel beam, a paraboloid is the shape you want (no question about it). If you want to focus from one point onto another point, an ellipse is the right shape. Normally, we beam radio waves many wavelengths away (=∞) so you use a paraboloid - like the above sketch - and you put the drive at the focus. The more you spend on size, the narrower beam you get.
All parabolas are, essentially, the same 'shape' - unlike ellipses and hyberbolas, which have a variable parameter, other than just scale.
Splitters are generally made of 1/4 wavelengths of coax cable. A 50 Ohm source can be fed to two 50 Ohm aerials. A 1/4 Wave of 75 Ohm cable with transform the impedance to roughly 100 Ohm.. Two in parallel brings you back to 50 Ohm. 4 x 50 Ohm aerials are combined using 1/4 Wave of 50 Ohm cable. Paralell two 50 Ohms gives you 25 Ohms. A 1/4 Wave 50 ohm cable will transform this to 100 Ohms.. Parallel to get beck to 50 Ohm.
Combining/Splitter two aerails. The resistor is not required if both aerials are always connected.
http://www.rfengineer.net/wp-content/uploads/2009/02/clip-image0023.gif
http://www.radio-electronics.com/in...itter/wilkinson-splitter-combiner-divider.php
Thanks very much for that insight.
Now I see a little more clearly that S:N is actually a function of the area of the collecting dish or trough.
Is there any advantage in splitting the signal between several small parabolic troughs rather than 1 large trough?
Cheaper, because you are basically paying for area. As I said earlier, you can get good acuity this way (basis of interferometers) but the SNR and purity of pattern will suffer.
You need to bear in mind that it's the two dimensional aperture of the system that governs the received signal power (the vertical and horizontal radiation patterns). Is your beamwidth dictated by directivity (i.e. eliminating interference) or signal gathering power? To get an optimum solution you really need to specify a lot of things.
I haven't come across multiple paraboloids, used side by side. Usually the simplest arrangement will be a single dish as big as you can afford or fit on the support. The problem with big dishes can be windage and many big arrays (again it depends on the frequency used) use stacks of Yagi arrays. Even then, the mutual impedance between elements can result in strange frequency responses and radiation patterns and spacing can be critical. I do remember some simple 'trough' antennae, used for low power UHF TV transmission where a good front-to-back performance was needed. They weren't paraboloids - just 'bathtub' shaped troughs, made of aluminium sheet, pop rivetted together. Complicated home-made arrays are not really to be recommended as the elements can end up 'talking to each other' and you wouldn't know it if you couldn't actually measure the radiation pattern. It's a bit (a lot, actually) like loudspeaker design. Many home made speakers can sound impressive but they may have awful phase / frequency responses which may show up on critical programme material. Simple 'squeaking' in a living room doesn't tell the whole story and no more would waving your antenna about, whilst observing the received signal level. Best to go for a simple system which is less likely to behave oddly. There are a lot of books and articles that discuss antenna arrays but not to much information of how to make the damned things work properly. Even trying to make a good simple bottom-loaded whip antenna ends up with 'suck it and see' with pliers and a VSWR meter (unless you use an already published design.
I think I've been given some very good, practical advice, which I think I would follow very closely if a good, practical system were my goal. However the particular thing I have been playing with, and have done some experiments with in audio, is an array.
It looks to me as though an linear array at half-wavelengths, with all signals summed in correct phase, both gathers by constructive interference and rejects by destructive interference at a S:N determined by the number of aerials in the line. (The arithmetic suggests that the wavelength is immaterial for long arrays, except that the aerials are still tuned devices.)
I'd like to try making up a link and measuring its performance, just to see how good a link I can make with not much technology.
You are pursuing some good math there. I'd suggest calculating the efficiency of multiple dipoles in a linear array, versus a single parabolic receive antenna structure, with the size of the parabola approximately equal to the length of the array. Would be a pretty interesting result!
One good idea is to cast your eyes upwards whenever you go past a comms mast. I have only seen large linear arrays of dipoles used for 'main station' broadcast transmitting antennae (VHF and UHF) and the arrays have been vertically stacked to get a narrow vertical beam - to get the kW where you want them. You mostly get dishes (or cheaper reflectors) and Yagis for anything other than very up-marker systems.
There's little wonder that the Yagi array (and two or three stacked) is such a popular solution because it is cheap to engineer, low windage. But the Yagi is no 'fun' to design and the calculations for the parasitics involve 'trusting' in some harder theory. I did design a very impressive looking (though I say it myself) 2X3 element transmitting array using monopoles rather than dipoles, operated at mf. It was pretty massive (you can still see it on Google Earth aamof) and it laid down the predicted field strength at the target distance, no appreciable interference where it wasn't wanted and also matched to the feeder as expected.
A point that hasn't been made yet, of course, is that a linear array with no reflector will have as big a backwards beam as its forward beam. This could be an embarrassment and an 'end-fire' arrangement is one way of dealing with this.
sophiecentaur said:
One good idea is to cast your eyes upwards whenever you go past a comms mast. I have only seen large linear arrays of dipoles used for 'main station' broadcast transmitting antennae (VHF and UHF) and the arrays have been vertically stacked to get a narrow vertical beam - to get the kW where you want them...
Some time into this "interference canceling" project, which I undertook on the excuse to myself that I might find a way to minimise the harmful effects of all-night dance "raves", I remembered having seen an aerial stack like the one you describe.
The aerial stack I saw was not quite the same thing I'd was working on, I decided, because if it were, the radiation would be normal to the flat planes of the rectangular array.
I also excused my continued research on the grounds that the explanations I found offered for arrays were couched in difficult terms I was not used to dealing with, and I wanted a "Grandmother" level explanation without compromise on accuracy.
Such understandings are valuable to us I thought, they can enter into the demotic and become well-known unlike the double-integrated frequency transforms beloved of the professional engineers.
I sometimes teach kids maths, and the confidence that this kind of work gives me rubs off and helps my pupils develop their own confident interpretation of numerical results in the real world.
Useful analysis of new phenomena is easier for those who have broken ground in analysis already, this is as much true for me as it is for my pupils, who benefit from appreciating that I do understand and am not merely reciting from a book.
Some of them go on to find new things out for themselves!
In the matter of aerial 'efficiency' an early result from Wikipedia's formula is that a dish of 1 wavelength aperture has an insertion loss and not a gain. I'd be better off with a ground plane at a half wavelength behind the array.
That's a mighty small dish. The suggestion in this thread was not a dish, it was a reflective trough (sp?) with a dipole at the focus. That's different from a microwave dish...
Well, maybe not fundamentally different. But yes, you would want the gathering area of the reflector to be several wavelengths if possible for best gain.
It wouldn't be surprising that an 'infinite' ground plane would do better than a tiny dish, would it? You need an aperture in the order of λ/(required beam width). The dish is, more of a diffractor than a reflector for small sizes - it's not geometric optics under these conditions.
@poor mystic
All of this simple antenna array theory starts with the calculations for the 'two slit' experiment. The first minimum occurs in a direction where the path from one half of the array is a half wavelength differs from the path from the other half by a half wavelength. It's 'just' a matter of adding the contributions of each element vectorially, taking into account the different distances when off axis.
The Fourier relationship between spatial distribution and radiation pattern is nothing to be overwhelmed about; it's only a Mathematician's show-off trick to get an answer (well - errr.. there is a useful fundamental principle involved too). But you can calculate the radiation pattern of an array of a few elements easily with a simple spreadsheet. Simply calculate the geometry and path length differences for signals from each element - then add them all (phase-wise) together. Do it over a range of angles and you can plot a radiation pattern without going near an integral, transformation or convolution!
Just add the cos(θ) for each element, where the θ = path difference / λ (in radians, or your angles may come out wrong!)
Once the spreadsheet works, you can change numbers and spacings (and even weight the elements differently) by just 'turning the handle. It borders on the 'good fun' region.
Sorry, guys
Other matters have intruded and I haven't been able give this the time it deserves, as a consequence.
I have, months ago, done as suggested and produced a series of polar plots, and full-field plots, whose characteristics include better than 20 dB rejection at 5 degrees off-axis and no sidelobes.
What I most strongly suspect is that this theory must already have been well-investigated for use in radio-telescopy, since if I am right a stack of wide-band antennas could be employed in a 2-D grid to that effect. Mechanical phase adjustments or mechanical displacement of the array could steer it.
Another consequence of the idea is that if an increasing phase lag were to progressively delay the aerials across a grid, a swept frequency would provide a geometric scan usable in radar. A sweep in the perpendicular might with ingenuity be possible on the same array.
I'll get back to the forum in a week or so with newly calculated plots pertaining to this thread.
poor mystic said:
Sorry, guys
Absolutely a well-developed field. Search on phased array radar, and you'll see lots of fun geometries and techniques. Heck, we even had a phased array HAM antenna setup a year ago at Field Day, with 4 antennas with variable phase delay feeds to focus the pattern in different directions. I think it was a 20m array, but I could be wrong about that. Didn't matter much anyway, because the skip sucked last year. Much better skip this year though!
Thank you very much.
Then is it possible to drive a rectangular plane as a very dense array, whose elements are touching?
I wonder whether copper mesh could be cut to the arc of a circle to feed the plane. By increasing the diameter of the circle the bellying in the path could be made arbitrarily small.
It sounds like easy low-noise comms so far. Surely there's a catch?
Maybe you could draw what you have in mind.
You can split a flat sheet of metal into two halves and feed the halves with RF, but it will act pretty much like a dipole.
Flat planes of metal generally form omnidirectional or donut shaped radiation patterns. It is a bit like getting magnification from a plane mirror. You really can't do it.
An example is the slot antenna.
Believe it or not, a slot cut into the surface of a flat piece of metal can radiate. This is done at microwave frequencies ie 2 GHz up.
See this site and the links in it:
http://www.antenna-theory.com/antennas/main.php
  • #31
I must be very stubborn, or something, on this because I keep thinking of tens, or hundreds, or thousands of dipoles closer and closer together, and wondering about making a plane resonate in a similar mode.
from an earlier post:
"A dipole in free space will have an impedance of about 72 ohms if driven at the centre.
I am attracted to the idea of an r.f."wave machine", which if I read the above-quoted idea correctly ought be drivable from a standard r.f. amp at ordinary voltages and impedances.
The drawing shows a very sparse version of what I have in mind on the matter of feeders.
I wonder whether the many coaxial feeders driving many dipoles could be replaced by a single distorted planar feeder driving a planar dipole, to achieve a high degree of spatial selectivity.
  • #32
and if not, why not?
  • #33
I'm not sure what actual layout you have in mind but the "catch" may be in the fact that you have to consider the total path length of signals from feed to each element. What did you want this circular plate to achieve? Perhaps a simple diagram. . . . .
  • #34
This is where a simulator can help.
I put 4 dipoles, each 39 inches long and mounted one above the other, into Eznec Demo V5.
At 1/4 wave spacing, 20 inches, there was about 4 dB gain over a dipole even though there was already massive interaction between the dipoles. The two in the middle were most affected and showed poor SWR at the resonant frequency of the other outer dipoles.
I have attached a copy of the EZ file for this. It needs to be unzipped and placed in the ANT directory of EZW in Program files.
Feeding each dipole at 180 degrees relative to the one next to it produces a gain of about 7dB over a dipole but directed in the line of the dipoles (ie up or down in this case).
You have probably seen TV antennas where the feedline went to each element but crossed over to the opposite side along the support boom each time. This is a similar antenna.
The SWR for this arrangement is pretty poor for all dipoles and would need to be adjusted by rearanging the lengths or spacings of the dipoles.
Placing the dipoles 2 inches apart and feeding them in phase resulted in radiation that was mostly along the line of the dipoles but with severe interaction between the dipoles. Gain was less than for a dipole in any direction.
If you can, try to locate a copy of the ARRL Antenna Book. A lot of these antennas have been around since the 1930s.
  • #35
I see I am having trouble explaining my idea, so I'll try a new tack on the question.
What happens if (say) 500 dipoles are placed in a row 2 wavelengths long?
If the very dense array I describe works, then a planar aerial resonating in the proper mode should also work.
If a useful oscillatory mode is to be excited in the plane, an EM wavefront from the r.f. amp must reach all points along the side of the plane at once.
If all points along the side of the plane are to be excited simultaneously, then the path length from the r.f. amp to every point along the side of the plane must be equal.
A geometric figure whose radius is the same for all points on its circumference is a circle. Hence a section of a circle can be considered for the geometry of a feeder intended to supply a parallel wavefront to a load.
This inspires me to think that a suitable driver for the plane might be a long feeder, which gradually spreads out, as does a slice of pie, along the course of the path from the r.f. amp. The length of the feeder then determines the arbitrarily nearly simultaneous arrival of a wavefront from the amp along the driven edge of the antenna.
I attach a further drawing.
  • #36
attachment came through this time...
  • #37
If you did manage to feed it like that, radiation would be along the plane of the dipoles, not at right angles to it as you suggest.
Try the simulation. Even with 4 dipoles, you can see the pattern of what would happen.
In the wires section, you can adjust the spacing of the dipoles just by changing the Z values. Starting at 600 add your first spacing, then the next etc.
  • #38
I haven't understood why you want such a dense array. Your simulation has shown the high degree of interaction between close elements, which affects the pattern (as well as costing you more in materials). By using in the order of λ/4 spacing your pattern doesn't change much and, for the same number of elements, you can get a bigger aperture and tighter pattern.
  • #39
vk6kro said:
If you did manage to feed it like that, radiation would be along the plate, not at right angles to it as you suggest.
Unfortunately I am still very busy but the radiation pattern predicted by the EZNEC simulator looks very like what I would expect from my own investigations.
I am encouraged to think that an increasingly dense row of aerials placed on an axis increasingly more than a wavelength long must obey the superposition theorem and effectively project a signal in an increasingly tight beam.
  • #40
The aperture of the beam will limit the beam width (diffraction limit) unless you start to introduce wildly weighted / in alternating sign current for each element to form a 'supergain array', for which the beam width can be made arbitrarily narrow, but at the expense of sidelobe levels.
As the elements get closer and closer together, the effects of mutual impedance between each element and all the others gets more and more so actually driving the elements becomes harder and harder
Why the obsession with very dense arrays, anyway? They are not good value, I think.
Does the EZNEC simulator include the whole mutual impedance matrix, btw?
  • #41
the idea of a very dense array is only that a plane aerial ought be like a very dense array. If this is so, then I can get good directivity using a plane aerial. The advantage would be that there would be no need for the great labour of setting up the many dipoles.
  • #42
It is certainly possible to get flat plates of metal to resonate and to radiate. They have to be comparable in size to a half wavelength at the frequency in use or very little of the power supplied to them is radiated.
The problem is, basically, that a flat plate of any kind has a lot of wind resistance and it can produce extra loading on an antenna mast or tower.
There have been attempts at making very compact antennas which are basically a radiating capacitor. Claimed results have mostly been attributed to radiation from the feedline.
EZNEC gives very reliable results, provided you give it accurate dimensions. The impedance at the feedpoint is given over a range of frequencies (at the bottom of the SWR chart as you move the cursor along the graph) and currents in the elements are given in chart form.
I only know the program works by dividing the parts of the antenna up into segments, which are really point sources, and these interact with all the other segments in the antenna.
The free version of the program allows up to 20 segments, which is plenty for simple antennas. Using more segments gives a more accurate result.
The author of Eznec is a regular contributor to the antenna newsgroup
REC.AMATEUR.RADIO.ANTENNA
and his expert comments are fun to read.
  • #43
Apart from the possibility of Supergain arrangements, which have doubtful benefits, overall, why not use a reflector and a suitable tailored feed? You get a pattern which approaches the diffraction limit in performance, has a good front to back ratio and has an established pedigree. I still see huge difficulties in feedin an array which is densly packed yet such little advantage, if any. If the elements are fed in a way that is easy to achieve, how can the pattern be much different from that of a more sparse array? I presume that you are wanting a realistic solution to the problem - even if you may not want to actually build it.
  • #44
A diagram would still help. I can't really envision what you have in mind in practical terms.
  • #45
Diagrams were included with post 31 and 36. I can re-draw anything that is unclear...
  • #46
I can see that diagram of a 'wide dipole (or half of it), fed with a tapered line but the EZIP attachment doesn't seem to work for me.
Basically, what I can see gives no control over the currents in the various parts of the radiator. They will just settle down as a form of standing wave, as all radiators do and the arrangement will be like a wide dipole. If your feeder is of a practical length, there will be a phase tilt from centre to edges and such a feeder would be a pretty good radiator in itself.
I just don't see where this is going. You want a beam, why not use a yagi or a dish? They work very well and are predictable. Your array is, by definition, a linear array rather than a two dimensional array so it wouldn't have much vertical directivity.
  • #47
Like any conceited fool or ordinary man, I hope to break new ground and accordingly worked on a "broadband wave field" concept. I found a suitable effect predicted for a flat aerial (if it could be made to radiate evenly) or a row of closely-spaced aerials.
If I wanted a link there are much better ways to go about it, I agree.
  • #48
Thank-you to everybody who contributed to this thread.
I believe I now understand a lot more than I did, though it is quite possible that I am yet on some path of folly.
In formulating a set of ideas intended to help me define a broadband sound-field, I noticed that since superposed waves are found in electromagnetic fields, the same ideas I was investigating for use with sound might also be useful in radio.
The logical conclusion of the design theory I ended up with for a sound-field radiator is a planar speaker all of which moves at once with no flexing. (Such speakers are suddenly on the market.)
Therefore I became interested in doing the same thing with radio waves - i.e. I would try a planar aerial.
At last I see a reason a planar aerial might not work in the same way as a planar loudspeaker.
The reason I see, that a planar aerial might not work as I would wish, is that the signal received by each section of the copper plate is only partly the signal directly from the mast. Each part of the aerial must also re-transmit the received waves, through the copper at a speed different from that of free space. Therefore confusion and phase mismatch result, and the aerial is useless.
Perhaps, if the speed of the signal through the medium (copper plate) were reduced to exactly half the speed of light there might be something interesting happening.
I'll investigate ways of achieving that.
  • #49
Interesting.
I think the main snag with your 'equivalence' argument is that sound is a longitudinal wave whereas em waves are transverse. There are a lot of major consequences in the design of a radiating arrays. There is not the equivalent to a continuous planar em radiator except for a reflecting antenna - which is fed with waves which have already been launched.
Let's face it, your picture of a wide single radiator, fed with a long tapered feeder achieves no more than illuminating a reflector using a single feed - except that you actually get directivity with a reflector!
I have seen some flat plate speakers and these certainly do work - although the fidelity is not too good because of wavelengths and dimensions. Making the plate the optimum dimensions and feeding it in the right place gets you a long way towards a usable / cheap / small loudspeaker.
Slow wave structures down to c/2 aren't a problem - even a sandwich of plates with polythene dielectric (stripline) will have a speed of about 2c/3. A crinkly arrangement could easily give you the required transit time reduction. But how will you couple this to a two dimensional array - as you could easily do with a loudspeaker array ?
I have just thought of another significant difference between sound and em radiators. The signal can only be distributed 'within' an em antenna at slower than c, whereas it can be distributed as fast as you like within a sound radiating system (e.g. electrically) compared with the speed of the sound. The sound waves can travel across a flat plate faster than the speed of sound in air, too.
One positive aspect of your 'thought project' is that it has given you a lot of food for thought about antennae in general - it's all good stuff!
  • #50
"One positive aspect of your 'thought project' is that it has given you a lot of food for thought about antennae in general - it's all good stuff! "
Very definitely so!
Considering the idea of the physical aerial as containing a sea of electrons held in place by the body of +ve charge represented by the atomic nuclei, I imagined the electron sea as being disturbed by impinging radiation.
Let us consider only those parts of the aerial which are at multiples of half wavelengths in free space from the centre of the aerial. Signals arriving at these places cause ripples in the electron gas which radiate at c for the medium and are superposed throughout the aerial.
At the centre of the aerial, looking from the bottom edge we see a resonant path at the frequency of interest running directly across the aerial. A second such resonant path exists on either side to the left and right.
The cycle of radiation which arrived at the outer aerials one cycle ago, arrives in phase with the new cycle if the distance between aerials is one wavelength at the f of interest in the copper, and if c in the aerial is half c in free space there can be no destructive interference from that source...
but suddenly I'm not so sure that this was the problem
