b.shahvir
- 284
- 24
In this type of arrangement is induced emf influenced by flux cutting also or only rate of change of flux linkage?
It is rate of change of flux linkage.b.shahvir said:In this type of arrangement is induced emf influenced by flux cutting also or only rate of change of flux linkage?
I understand but aren't the side conductors of the coil also getting cut by the non uniform flux density sweeping across it and as a result also contributing to induced emf quantities? Just a thought.Baluncore said:It is rate of change of flux linkage.
Draw the magnetic field of your magnet.
Draw a circle about the mid-point of the magnet with a radius equel to the distance to the coil.
Plot the rate of change of line density crossing that circle, around the circle, to get the induced voltage.
It is the rate of change of the number of lines passing through the area of the coil. It has little to do with bits of wire, it is all to do with an area.b.shahvir said:I understand but aren't the side conductors of the coil also getting cut by the non uniform flux density sweeping across it and as a result also contributing to induced emf quantities?
So if I may presume, as a hypothetical case for that matter, the side conductors of the coil are of significant length. Will the flux cutting have any considerable influence on the induced emf in this case?Baluncore said:It is the rate of change of the number of lines passing through the area of the coil. It has little to do with bits of wire, it is all to do with an area.
The area of the coil is defined by the wire. If a line of flux enters that area, at the same time as another line of flux exits the area, then no voltage will be generated.b.shahvir said:So if I may presume, as a hypothetical case for that matter, the side conductors of the coil are of significant length. Will the flux cutting have any considerable influence on the induced emf in this case?
The above statement is valid for uniform flux densities but in this case flux density is non uniform and obeys Inverse Square law. Hence the the no. of flux lines entering and leaving the coil sides may not not be equal at that instant. A resultant emf would be induced in this case due to flux cutting and may contribute to the emf induced due to rate of change of flux linkage.Baluncore said:If a line of flux enters that area, at the same time as another line of flux exits the area, then no voltage will be generated.
When it comes to a coil, how do you define "flux cutting" ?b.shahvir said:A resultant emf would be induced in this case due to flux cutting and ...
Baluncore said:When it comes to a coil, how do you define "flux cutting" ?
I think the point lost is that a time change of the field magnitude alone will cause emf to be generated, no cutting of field lines involved. EMF generated is related to change of flux which may or may not involve lines being cut.b.shahvir said:A non uniform magnetic field when sweeping across the coil will also tend to cut the side conductors of the coil (assuming side conductors are of significant length).
Actually, the reciprocity integral relation I gave in #49 can be applied to this problem. One needs to use ##J_2=\nabla\times M## for the current. ##E_2## is then related to the generated voltage at the terminals to the coil. Integration by parts yields the integral of ##B_1\cdot M## over the volume of the magnet. ##B_1## is the field generated by supplying a current ##J_1## to the coil terminals. The only time (or angle) dependence in this integral comes from the angle ##M## makes with ##B_1## provided the both fields are uniform.Charles Link said:determining the magnetic field from a cylindrical permanent (uniformly magnetized) magnet is a necessary part of this more complex calculation, while the determination of the EMF in the coil is an additional calculation that is most readily done numerically, (computer methods).
What would? The calculation I outlined in #73 can be done for uniform fields in closed form. All the principles remain valid without the uniform assumption. Non uniform fields lead to the waveform distortions as many have pointed out. What remains that is unclear?b.shahvir said:This isn't helping in resolving my query .
Paul Colby said:What remains that is unclear?
Can you give us a reference paper where they calculate emf due to flux cutting by a conductor?b.shahvir said:Contribution of induced emf in coil due to flux cutting.
Delta2 said:Here in this example in the rest frame of the rotating magnet the wire of the coil is moving, so you can use the second method
They are guaranteed to be the same, check https://en.wikipedia.org/wiki/Faraday's_law_of_induction sections 3 (Proof) and 4 (EMF for non thin wires)b.shahvir said:Provided the results are same with both methods.
alan123hk said:I believe that Faraday's law applies to all situations, for example, the magnet is stationary and the coil is moving, or the coil is stationary and the magnet is moving, or both the coil and the magnet are moving, or the mutual inductance of the two coils that move relative to each other, or others.![]()
If this is a permanent magnet, so the strength of the magnetic field source itself does not change, then this should be a motion-induced electromotive force. You can use the Lorentz force (the cutting of the magnetic field) or the change in the magnetic flux through the coil to calculate the induced voltage. Both methods should get the same answer, but I don't think the two methods should be used at the same time. As for the method to be used, it depends on the actual situation and each person's choice.b.shahvir said:Absolutely. But in this particular case the contention was which method is best applicable (or both) to the rotating magnet case.
From the arrangement it implies that two situations are applicable to this case;
1) 'Statically' induced emf due to rate of change of flux linkage with coil (transformer simulation)
2) 'Dynamically' induced emf due to cutting of magnetic flux lines by side conductors of the coil as a non uniform magnetic field sweeps across the coil (dynamo simulation)
I believe the above 2 types of EM induction would give rise to individual emfs which may contribute as a whole to the total induced emf value in the coil at a particular instant.
All changes in flux through the coil will result in "cutting" of flux lines. Either the lines move apart or the coil moves to a region of different line density. The results comport with Faraday's Law in either case.b.shahvir said:I believe the above 2 types of EM induction would give rise to individual emfs which may contribute as a whole to the total induced emf value in the coil at a particular instant.
Charles Link said:Suggest you try the experiment if you have access to an oscilloscope.
I presently don't have access to an oscilloscope either. It would be interesting to see some experimental results.b.shahvir said:No I don't, that's why put query on forum.
