Wavefunction normalization help
The discussion focuses on normalizing the wavefunction psi(x) = A(1 - e^(ikx)) for the interval 0 < x < 2pi/k. The integral of psi multiplied by its conjugate must equal 1 for normalization. A user expresses confusion over the integration process and whether they correctly calculated the conjugate. Another participant clarifies the multiplication of psi and its conjugate, suggesting that the normalization constant A can be determined by simplifying the resulting expression. The conversation emphasizes the importance of correctly handling complex exponentials in wavefunction normalization.
CyberShot
psi(x) = A(1 - e^(ikx)) if 0 < x < 2pi/k
integral of psi * psi conjugate over all space = 1
the conjugate is psi*(x) = A(1 - e^(-ikx))
so when I multiply psi and psi* , I get 2 - e^(-ikx) - e^(ikx)
I can't integrate this? Please help! Did I mess up the conjugate?
Not knowing anything about wavefunctions, just on the information you gave me, I think you multiplied incorrectly (left out the A):
(A-Ae^(ikx))*(A-Ae^(-ikx)) = 2A^2-A^2*(e^(ikx)-e^(-ikx)) = 1
From there, I'm seeing a chance to divide by 2A^2, so you have something like 1-sinh(u) = (1/(2A^2)) where u=ikx.
EDIT: Also, I assumed x, A, and k are real.
