Wavelength of a wave in a closed tube
In a lab experiment with a closed tube and piezoelectric transducers, the discussion centers on calculating wave velocity and understanding resonance frequencies. The lab manual states that the tube's length corresponds to one wavelength at the lowest frequency, but there is confusion about whether it should be considered half a wavelength due to the presence of antinodes. Clarification is sought on whether the setup involves a tube closed at one end, affecting the wavelength calculations. The relationship between resonant frequencies and the number of waves within the tube is also questioned, particularly whether it increases by half or a whole wavelength. Understanding these concepts is crucial for accurately determining wave velocity and resonance behavior in the experiment.
warfreak131
In a lab that we performed, we had a closed tube with piezo electric transducers on both ends, and they were attached to a frequency generator. We found the frequencies that caused resonance, and the lab wants us to calculate the velocity of the wave using data. The lab says that there are antinode pressure waves at both ends, and therefore, the length of the tube is equal to one wavelength at the lowest frequency.
But at the lowest frequency, wouldn't one antinode to the next correspond to half a wavelength? The two anti nodes in question would be one antinode with max positive displacement to one with the max negative displacement.
You are right, there is half wavelength distance between the antinodes. But it could be that those transducers generated in-phase pressure changes, then there was one wavelength between the ends.
ehild
so should i go with my gut and say half wavelength or trust the manual to be right?
also, assuming its a full wavelength, it asks us to find the velocity at higher resonant frequencies. so would the number of waves inside the tube increase by 1/2 or by a whole when another resonant frequency is reached?
I am confused about the set-up of the experiment. Was that tube exited at one end and closed at the other end where the pressure was measured? The pressure can have antinode at a closed end, but than the length of the tube is L=((2n+1)/4) λ with n=0, 1, 2, 3, ... If the tube was either closed or open at both ends it was a half wave between the ends in case of the fundamental frequency. In case of the other resonant modes, the length of the tube is integer multiple of the half wavelength: L=n(λ/2).
See http://en.wikipedia.org/wiki/Acoustic_resonance#Cylindersehild
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
