How Do You Calculate the Wavelength of Particle Motion in Parametric Equations?
Logarythmic
I have two parametric equations for the speed of a particle in a plane:
\dot{x}(t) = A \left( 1 - cos{\Omega t} \right)
\dot{y}(t) = A sin{\Omega t}
The period is equal to \Omega. How do I find the wavelength of the motion?
The wavelength is just \lambda = \Omega v, where v = \sqrt{\dot{x}^2 + \dot{y}^2} is the speed, right? But then the wavelength is not time invariant. Could my answer
\lambda = \Omega A \left( 2 - 2cos{\Omega t} \right)^{1/2}
really be correct?
Here omega is not the period, but the angular velocity = 2pi/T where T is the period.
I thought about that too, but it's stated in the problem that the motion is periodic with period \Omega. Anyway, my question still remains.
Is this problem in a textbook, or was it given by a professor or teacher?
\Omega as a period would seem to be incorrect since normally the arguments of sine and cosine are dimensionless, which is consistent with rl.bhat's comment.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
