How do EM waves propagate in spherical emission?
In summary: With EM waves, its similar in that there is an oscillating electric field perpendicular to an oscillating magnetic field. However, the electric field and magnetic field are at right angles to each other and the direction of propagation. So when an EM wave hits something, the electric and magnetic fields oscillate and create photons.
  • #36
Consider, if you will, an electron orbiting an atom. That electron exists on a shell of constant energy about the atom. If this electron were to move to a lower energy shell, a photon is released to conserve energy. This photon propogates outward equally in all directions at the speed of light - compressing the spatial dimension representing the shell's diameter to zero (radially) by Lorentz contraction. At any given point in space, that pseudo electron shell (representing the change in energy) can then be pojected on a sphere of constant time with respect to the emitting atom. The phase of this pseudo-electron orbit does not vary with time at our given point, but it will vary with radial distance from the emitter. The entire orbit of this pseudo-electron can then be construed to exist at a point (or "patch") on a spere - only by varying radius can you "observe" the sinusoidal amplitude of the wave as its' complex amplitude varies through 360 degrees (one wavelength).
Is this the 2D scenario you were referring to? I actually just reread the whole thread and came across it and looked at it under new light. However I don't come close to fully understanding what you are saying...note that I have pretty much no knowledge of relativity or the mathematics I believe you are speaking of. If there is an easier way to put it, I'd appreciate it, otherwise don't worry about it.
there may well be another (the same?) traveling in the opposite direction (and 180deg out of phase)
I am talking about one singular photon being emitted. So there may not be another photon emitted in the opposite direction. Imagine then a H atom with an electron in the first excited state; it can only emit one photon - to conserve energy - and thus the H atom must now move to conserve momentum.
An atom that emits a photon does still lose mass in the process; so how else could that instantaneous change in mass convert itself to a photon (wave, or otherwise)?
I am not sure if when a photon is emitted the atom loses mass...? The photon has no mass, but has momentum. The electron loses energy, so a photon is given off...i.e. energy.
Well - the way I see it is that the total energy of the wave exists in different directions at different times due to the nature of the source (an orbiting electron). The suggestion that one could capture all of the wave energy at a single point in space strikes me as absurd.
Firstly we are talking about a singular photon, so its energy can only be in one place. There is a probability of it being anywhere on the surface, but it's energy is only at one point. This is I think where we disagree the most, and maybe we need some others' opinions?
Kcodon
  • #37
To cbacba,
One thinks of the sine waves as that is going one when creating the wave - such as a radio transmitter and the sine wave represents a pure or single frequency. For the wave propagation, special relativity demands that time is stopped when moving at the speed of light so there is no oscillation happening in the wave itself. Rather the oscillations appear to happen at a fixed location as the wave ripples past due to the fact it is traveling at a velocity (c) and it has a wavelength which is a separation of these 'dents' which are the presence of an electric field perpendicular to a magnetic field.
I didn't understand this before but re-reading this again, I have a few questions. Firstly the wording of the first sentence confuses me a little...do you mean to say the sine wave represents say the electric/magnetic field in the source, with respect to time? And then does this mean that there is one "dent" per photon. So if the electron in the radio transmitter oscillated once, this would be one dent, representing one photon, and one wavelength? So then the apparent oscillations at the fixed locations are in fact just measures of the amplitude of these dents so to speak...i.e. the strength of the electric field at that point in space, with respect to time? So again somewhat like a sound wave...if you plotted the amplitudes with respect to time you would get a sine wave?
Thanks anyways,
Kcodon
  • #38
Wave or Particle
As far as I understand Quantum Mechanics, if we know the path of a photon, then we observe particles (not waves) but if we have no information on the path (as in Young's slits) then the photon 'is' a wave and exhibits interference to prove it.
In the case of a single photon starting out in free space and being 'oberved' by one telescope 10 miles away, then if we observe it, we know its path exactly so it must be a particle. But, if we don't observe it? Does it mean its a particle that shot off in the other direction to our telescope, or the fact that we did not observe it means that we could not know its path, (we didn't observe it) so it must be a wave. If its a wave, we did not observe it because of the radiation pattern from a small dipole denies us its observation. OR, we did'nt observe it because its a particle photon and we would then knows its path exactly, and that path is impossible because the photon went the other way.
  • #39
Spontaneous vs stimulated is always possible. Stimulated works as a laser when there's a bunch of atoms / molecules in the higher energy state ready to drop down. All it takes is one spontaneously emitted going by to do so. Spontaneous depends upon which states as to whether you're talking nanoseconds or seconds for a decay time. Forbidden lines are like the latter. Collisions also play a role in changing energy levels both up and down. Stimulated also has liklihoods of happening depending on the line (beginning and end states).
Conservation of momentum demands that the atom recoil since a photon has energy and momentum - proveable by the radiometer toy - if sufficient vacuum it turns away from the white sides dues to 2x momentum from reflected light, if not enough vacuum it moves away from the black sides as there is heat and interaction with the vacuum gases overwhelming the 2x momentum coming from the white side. Look at a whole batch in store selling them sometime.
One too must remember that according to modern physics, EM waves are all the same stuff from different viewpoints. X and gamma rays don't show much wave behavior. What's more, even traveling huge distances with regard to the size of the universe, they red shift a bit (expanding U. and all that) but they don't dissipate out in inverse sqr and neither do other forms of Em. It's an all or nothing proposition. The difference between a hard gamma ray and a 200meter AM broadcast station 'photon', according to special relativity, is the speed at which you are approaching the broadcast station's antenna.
Note too that photons/EM waves are properties of space very much like waves on the ocean. They are not properties of the atoms/molecules or antennas emitting them.
For an antenna, I've read that EM waves actually form outside at the point where the E and M fields are perpendicular to each other (and in a particular phase relation?). This may be perhaps one or more wavelengths out. One may also be taught conceptually that the propagation is happening because each changing field is propelling the other forward - along the poynting vector. These changes are ovservable at a fixed point in space where the transmitter/antenna is located. There no time variation in the frame of reference in which the wave is traveling. Whether a photon has 1 full cycle, 5 or 5000 cycles of waveform in it, it's a fixed pattern moving though space at the appropriate c velocity. It only appears to oscillate for a stationary observer (or at least one moving at less than c).
There are other examples of what seem like similar circumstances going on in physics. Temperature is a bulk property of a huge bunch of molecules / atoms/ electrons / photons etc. Matter, like the skillet on your stove or the air in your room tend to have a measurable temperature and that means they are are following the Boltzman statistical distribution of kinetic energy. It's like the blackbody curve. A particular atom will have the liklihood of having a particular energy according to the Boltzman distribution but that particular atom will not be measureable without modifying it (bouncing some energy off it or letting it change state somehow and detecting it). That atom will not have a unique temperature as it is the statistics of the energies of all of the atoms that create what we call temperature.
Perhaps that is too close to qm and how things are being interepreted. We ascribe probabilities and perhaps even more to single objects for which we have no way of knowing the specific details and then expect the bulk properties of a whole batch of them to be directly applicable to a single hypothetical example. If an atom is an isotropic radiator and we let it sit there radiating its little heart out for a long enough time, we will get a uniform distribution for a radiation pattern. If we put a double slit in there and shine coherent light at it, we'll see a diffraction pattern. If we shut down the intensity even to 1 photon per second, we'll measure the same pattern eventually as it builds up. This leads to the qm conceptual assumptions of traveling through both slits at the same time and a photon interfering with itself. And, supposedly it's been tested quite properly that closing one slit at a time while building up the pattern via single photon emissions results in the destruction of the waveform - implying that photon does travel through both or is somehow 'aware' of both slits.
So far, I've yet to find a satisfactory conceptual answer which is even close to being correct. And, it would seem that things get even worse when considering things when dealing with astronomical distances.
  • #40
kcodon said:
To cbacba,
Thanks anyways,
Kcodon
I use the term 'dent' for lack of a better understanding of what an electric field is. It's the problem of everything is defined in terms of the fundamental undefinables. The general relativity guys like to conceptualize gravity by having matter bend their euclidean space table down so I thought I'd do likewise. Think of it as a deformation in the 'electric' direction as opposed to the 'up' direction.
Generally, the sine wave refers to the electric field or the displacement of molecules in air for a sound wave or the displacement up and down for the height of the water in an ocean wave. It is generally used for waves of a uniform single frequency and other more complicated waveforms can be created from combinations of multiple sine waves.
The photon is thought of a packet, statistically having a certain size or length. Even a sine wave of non infinite unchanging length tends to be represented by multiple sine waves - implying certain conditions and perhaps limitations on how pure a single frequency there is.
I don't know for certain hardly anything about a photon. However, they should be essentially of a single frequency and the implication being that it is a multiple of wavelength. The energy and particle nature of an AM broadcast station transmission is masked totally by the fact the photons are of such long wavelength and low energy. Again, it's the properties of space that define how it works.
In general at a fixed point you should get an electric field behaving with a sine wave magnitude - antenna input to oscilloscope display sort of thing.
  • #41
Thanks so much cbacba,
I found this bit the most helpful:
And I think now with your explanation and others, I think I know what's going on with EM radiation to a much greater degree. I'm going to let this new found knowledge settle, however I'm much happier with my understanding and for now I don't really mind whether its right or wrong! :smile:
Thanks again to all,
Kcodon
  • #42
Don't sell yourself short - "understanding" is beleiving you are right, when others say you are wrong. Here's to making your "understanding" more robust (clink).
Regards,
Bill
P.S. Treat your "understanding" objectively: correct a neccesary, and keep going.
  • #43
Cheers!
And don't worry, I've got myself in the poop a few times with thinking I understand something that I soon realized I didn't - so I'll be objective. However its much nicer to have your understanding proven wrong with fact, than to have it verbally beaten into submission by those who think they understand - whether they are correct or not :rolleyes:
Kcodon
  • #44
Heisenberg's principle says that if we know the momentum of a photon exactly, then
we cannot know its position at all. Now a photon of an exact frequency e.g. from a
laser - the ferquency is known exactly, therefore on its travel from A to B we cannot
say anything about its position.
All I am saying is that the situation is not clear. There is confusion arising from speaking
about EM oscillations (antennae etc), to waves (dents in space-time, etc), to particles that cannot be defined (QM). And one fixed-frequency photon starting out from the center of a spherical volume seems to defy all the logical explanations at once.
highlight the problems.
  • #45
actually, h defines just how well we can know both. For instance the freq. is very very close to the freq. of the laser and the photon is somewhere in the laser tube or beam coming from the laser. The object of the thought experiments has been an attempt to clarify concepts to a level that starts making a bit of sense. Some is just not going to. If nothing else, understanding some pieces that cannot be assembled into a whole is better than not understand the whole or the pieces. whether this will be resolved in our lifetimes or never is going to be an open question for a while.
One thing you can get rid of for comprehension is that there is no way you're going to exactly know anything, especially something like the position or exact energy of a photon. For one, it will have some energy because the atom/molecule will not be at rest because it will have kinetic energy due to temperature. Any measurement you make will be flawed, even a spectrometer will have a bandwidth or smear that means your result will only be so accurate. Note this doesn't mean it's the same thing as the qm limit, only that there are real limits. It's possible if not probable that a photon may not have just one frequency as it is of limited length (a packet). The same thing goes for position, it's not possible to determine exactly where it is. It's possible that being a packet, it may not have an infinitesimal size of a point or a definable and symmetric outer bound that permits the determination of a centroid for that point position.
  • #46
The only rationalization I can provide at this point (and it's been my interpretation for some time) is that a photon is an imaginary electron - representative in some way of the last orbit that was to be of the real electron in its' higher energy state.
The energy of the photon is real in the direction opposite the radial translation of the real electron, but imaginary in all other directions (this feature is new in my interpretation). The orbit of this imaginary electron grows radially at the speed of light, but continues with the same angular velocity of the parent electron in it's high-energy state (preserving it's wave nature).
If a ring of detectors were constructed in the plane of the electron's orbit, at constant radius from the orbit's center, one detector might receive the energy of the photon (where it's energy is real), but all should sense the change in periodic electric field variations due to the real orbiting electron (very nearly?) simultaneously.
Upon detection, (a portion of?) the real component of the wave energy is lost, but the imaginary component continues expanding outward - as if to signal the change in the real electron's state across space-time.
Regards,
Bill
  • Classical Physics
  • Electrical Engineering
  • Mechanics
  • Electromagnetism
  • Electromagnetism
  • Quantum Physics
