Weighing fluids with immersed objects
  • Thread starter Thread starter maxbashi
    Fluids Weighing
When a butterfly enters a jar without touching the bottom, it does not affect the scale's reading. However, once the lid is placed on the jar, the butterfly is contained, and its weight contributes to the scale's measurement. The discussion also touches on the concept of air pressure and flow, suggesting that air movement can influence the scale's reading. The idea of impulse is mentioned, indicating a relationship between force and motion in this context. Ultimately, the presence of the butterfly inside the closed jar does increase the weight measured by the scale.
maxbashi
So imagine that in an open room you have a big scale and on it you have a jar and a lid sitting next to each other. Imagine a butterfly floating into the jar but not touching the bottom. I wouldn't think this would increase the reading on the scale. But if you put the lid on the jar, closing the butterfly inside, would the reading on the scale increase (compared to when the lid was sitting next to the jar on the scale?) Would the butterfly be "pushing down" on the scale now?
Doesn't make too much difference if the lid is on. If there is air flowing to the bottom of the jar, the scale will pick it up. Look up impulse.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
