Weight displaced and volume displaced?
  • Thread starter Thread starter wrigglyworm
    Volume Weight
The discussion revolves around calculating the weight and volume of air displaced by a hot air balloon that is hovering with a total weight of 18,000 N. According to Archimedes' principle, the weight of the displaced air must equal the weight of the balloon for it to maintain neutral buoyancy. To find the volume of displaced air, one needs to know the density of air, which is typically around 1.225 kg/m³ at sea level. The hovering condition indicates that the weight of the displaced air is also 18,000 N, allowing for further calculations of volume based on this weight and the known density. Understanding these principles is crucial for solving the problem effectively.
wrigglyworm
you are hovering (no acceleration) in a hot air balloon of total weight (balloon+load+hot air) 18,000 N
a) what is the weight of displaced air?
b) what is the volume of displaced air?
if i knew i wouldn't be asking
i also do not know
Consider Archimedes' principle and the buoyancy force.
What's are the conditions for neutral buoyancy? What's the (standard) density for air?
Think about it this way. The baloon is hovering. It's not going up or down. Suppose it was slowly going down. Why would it be going down? Because every time it went down by 1mm, something heavy would be closer to the ground. That could be you in the baloon. But you're not going down. That means something equally heavy must have to go up when you go down. That's the displaced air. It must have the same weight as the thing that displaced it, because if it was lighter you'd go down, and if it was heavier you'd go up.
If you know what it weighs and you know its density, you can figure out it's volume. Do you know the density of air?
