Weinberg 5.9.34: Is Charge Conservation Resolved?
  • Thread starter stedwards
  • Tags
    Weinberg
In summary, Weinberg 5.9.34 discusses the antisymmetric tensor field for massless particles of helicity ##\pm 1## in the form ##f_{\mu\nu} = \partial_{ [ \mu } a_{ \nu ] }##. This is a tensor even though ##a_{\mu}## is not a 4-vector, and the gauge invariance of the Lagrangian allows for the reduction of the physical states to the transverse degrees of freedom.
stedwards
416
46
Weinberg 5.9.34
"[...] Using this together with Eq. 5.9.23 gives the general antisymmetric tensor field for massless particles of helicity ##\pm 1## in the form ##f_{\mu\nu} = \partial_{ [ \mu } a_{ \nu ] }##. Note that this is a tensor even though ##a_{\mu}## is not a 4-vector."​
Not a four vector? So the vector potential in the development that follows is not a vector, not Lorentz invariant, and most significantly, not generally covariant in this universe.
If ##a## is not a vector in the construction of a Lagrangian, either the action is not a scalar or the charge-current density is not a tensor, or both.
If we brush this under the carpet, a Lagrangian constructed to conserve charge is either not the Lagrangian of a conserved quantity (##dj \neq 0##) or the Lagrangian density is frame dependent, or both.
Is this later resolved?
You should read the commentary below (5.9.31). The reason that ##a^\mu## here is not a 4-vector is that Weinberg has already reduced it to the physical transverse degrees of freedom. An arbitrary Lorentz transformation will introduce longitudinal and timelike components that were not included in the definition of ##a^\mu##. The solution is to not make the transverse restriction by hand but to use gauge invariance to do it. Then the unfixed ##a^\mu## is a 4-vector, but the gauge-fixing can be used to reduce the physical states to the transverse degrees of freedom.
The point is that ##a^{\mu}## is a gauge field, which transforms according to a vector field modulo gauge transformations, i.e., you can always do the Lorentz transformation, introducing unphysical degrees of freedom and then gauge them away. Compared to the standard treatment, where you only do the Lorentz transformation, with an additional gauge transformation, you get the correct symmetric and gauge invariant energy-momentum-stress and center-momentum-angular-momentum tensors right away, without redefining it afterwards via an extra gauge transformation. At the end, both are the same, and a unique derivation of the energy-momentum-stress tensor is finally given by varying the metric, as we know from General Relativity.
1. What is Weinberg 5.9.34 and why is it significant?
Weinberg 5.9.34 refers to the section of Steven Weinberg's book "The Quantum Theory of Fields" in which he discusses the concept of charge conservation in particle interactions. This is significant because charge conservation is a fundamental principle in physics that helps us understand the behavior of particles and the laws of nature.
2. What is charge conservation and why is it important?
Charge conservation is the principle that states that the total electric charge of a closed system remains constant over time. This means that charge cannot be created or destroyed, only transferred between particles. It is important because it helps us understand the behavior of particles and the fundamental laws of physics.
3. Has charge conservation been resolved?
The concept of charge conservation has been well-established and supported by experiments for many years. However, there have been some theoretical debates and proposed extensions to the principle, such as the possibility of charge non-conservation in certain high-energy processes. So while it is generally accepted, it is still an active area of research.
4. How does Weinberg contribute to the understanding of charge conservation?
In the section of his book, Weinberg discusses the mathematical framework of gauge theories and how they provide a theoretical understanding of charge conservation. He also explains how the conservation of electric charge is related to other fundamental symmetries, such as gauge symmetry and time reversal symmetry.
5. What are the implications of charge conservation for particle physics?
Charge conservation is a crucial principle in particle physics, as it helps us understand the behavior of particles and their interactions. It also has implications for other areas of physics, such as the study of the early universe and the search for new particles. Additionally, any violation of charge conservation would have significant implications for our understanding of the laws of nature.
  • Quantum Physics
  • Beyond the Standard Models
