Schools Weird marking scheme for university course -
The course mark calculation formula combines term marks (T) and final exam marks (F) using a weighted approach. The term mark (T) is calculated as 30% from assignments and 70% from term tests. The formula uses 0.6 times the maximum of T and F, and 0.4 times the minimum of T and F, meaning it emphasizes the higher of the two scores more heavily. This system allows students to benefit from their stronger performance, whether in assignments or the final exam. For example, if T is 95 and F is 85, the course mark would be calculated as 91, demonstrating how the formula works in practice. It is advised to confirm any uncertainties with the course instructor for clarity.
saadsarfraz
Hi, I am doing this really crazy course at university, i need some help in understanding the final course mark calculation which is:
Course mark = 0.6max{ T, F} + 0.4min{T, F}
T = term mark = 0.3( average percentage on assignments) + 0.7( average percentage on term tests)
F = final exam percentage
what does 0.6max{ T, F} supposed to mean! the part where max{ T, F} is what i don't understand, max is maximum but what does {T, F} means??
any help would be really appreciated.
Term Mark and Final.
Sorry, I only read the last sentence, now I realize my answer wasn't useful.
My guess is that 0.6max{T,F} means "0.6 times the larger one of T and F", and similarly for min{T,F} so if T = 95 and F = 85, then the course mark would be
0.6 * 95 + 0.4 * 85 = 91
The result would be the same if the grades were swapped so T = 85 and F = 95.
However, you really should ask the course instructor / professor about this.
Basically it is a nice system, since it emphasize the part of the course you did best on. So if you ace the exam you aced 60% of the course with assignments worth 40% or if you bombed the exam you just bombed 40% of the course and got the assignments and such weighing 60%.
Isn't that obvious from what you wrote?
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
