What Angle Should a Projectile Be Launched to Reach Specific Distances?
To determine the launch angle for a projectile to reach specific distances, a ball is launched at 1000 m/s needing to travel 2000 m horizontally and land 800 m vertically. The equations of motion are used, leading to a calculated angle of approximately 22.4 degrees. However, the answer key indicates a second solution at 89.4 degrees, prompting confusion. The discussion involves verifying the calculations and understanding the dual solutions for projectile motion. Clarification on the methodology for finding both angles is requested, highlighting the complexity of projectile motion analysis.
clipperdude21
Projectile Motion PLEASE HELP MIDTERM TOMMOROW!
1. A ball is launched with a velocity of 1000m/s at some angle theta. The ball must travel 2000m in the x dir and land 800m in the y dir on a plateau. What theta should the ball be shot at to make this happen.
2. y=y0 +v0t -.5gt^2
3. I solved for t using x=v0cos(theta)t and plugged that into the y equation and got one solution. The answer key says there's two solutions. One at 20 something, which is the one i got and also one at 89.4 degrees. Can someone show me how to get the other/both solutions
THANKS! I appreciate it
You should use the formula
y=x tan theta - \stackrel{gx^2}{2u^2cos^2 theta}
THis formula is combined by
verticial component using s=ut+1/2 at^2
horizontal component v=s/t
i used that equation and still only got 22.4 degrees at the sole solution... 89.4 doesn't seem to fit. Is there an error in the answer key?
i also get the 22.4 degree
but it is acceptable that there is another angle is the answer...
however I forget how to solve it ~sorry
ok thanks anyway!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
