What are partial differential equations?
Partial differential equations (PDEs) are equations that involve the derivatives of functions of multiple variables, such as f(x,y). They extend the concept of ordinary differential equations (ODEs), which deal with functions of a single variable. Understanding PDEs requires familiarity with partial derivatives, which are derivatives of functions with respect to one variable while keeping others constant. Key examples of PDEs include the wave equation and the heat equation, which describe physical phenomena in various fields.
  • Understanding of basic calculus concepts, including derivatives and functions.
  • Familiarity with partial derivatives and their applications in multi-variable functions.
  • Knowledge of ordinary differential equations (ODEs) and their characteristics.
  • Basic algebra skills to manipulate equations and understand variable relationships.
  • Study the wave equation and heat equation to see practical applications of PDEs.
  • Learn about the Laplacian operator and its significance in solving PDEs.
  • Explore introductory textbooks on differential equations for foundational knowledge.
  • Research online courses or resources that cover partial differential equations in depth.
Students and professionals in mathematics, physics, engineering, and applied sciences who are looking to deepen their understanding of partial differential equations and their applications in modeling real-world phenomena.
awholenumber
If the slope of the curve (derivative) at a given point is a number .
What is your question ?
What are partial differential equations ?:cry:
Do you want PF to play textbook for you ? What did you find so far and what is unclear ?
I was wondering if anybody could explain this in this context
This question has no relation to the title. Partial differentia equations are not the same thing as derivatives (even though they are related).
I was hoping somebody would explain the relationship between the two
Where are you in your curriculum ? You seem to know what a derivative is -- for a function of a single independent variable, e.g. ##f(x)##. Right ?
Partial derivatives are a kind of extension to functions of several variables such as ##f(x,y)##: if you keep y constant, e.g. at ##Y_1## then the partial derivative wrt x of ##f## is the derivative of the now single variable function ##f(x, Y_1)##.
But you have googled such things yourself already, so I ask again: what did you find so far and what is unclear ?
(and perhaps also: what textbook are you using ?)
Thanks for the reply ,
I was going through this website here ,
https://17calculus.com/differential-equations/
From a pdf :
Basic Terminology
An ordinary differential equation (ODE or just DE) is a system with the following ingredients:An independent variable (usually t think ”time”or x think ”position”) that derivatives are taken with
respect to.
A dependent variable, i.e. function of the independent variable, e.g. y = y(t) ”the variable y which
is a function of t”.
A multi-variable function F that describes a relationship between the derivatives of the dependent
variable (taken with respect to the independent variable)
F(t, y, dy/dt, d2y/dt2 , . . . ,dny/dtn ) = 0.
Is it possible to understand partial differential equations in terms of a working example of something ?
This is the only thing i could think of .
Wrong website. This is about differential equations. Before going through that you should become familiar with differentials. An introductory calulus textbook or website if the Wiki link I gave you is too abstract.
Sure. Once you're comfortable wit Algebra, Calculus I and II, there are plenty in Calculus III on partial derivatives
I'm not trying to discourage you: it's more a matter of finding out what foundations you have as a start for your adventure
Not clear what you aim at with
I suspect you have some specific topic that interests you ?
It is ok , i sort of understand it with my new avatar .
Some points i tried to narrow down .
Differential calculus - which is looking at the instantaneous rates of change of objects with respect to some variables. We have the notion of the derivative of a function
The slope of the curve (derivative) at a given point is a number
Partial derivative - A derivative of a function of two or more variables with respect to one variable, the other(s) being treated as constant.
An equation that involves the derivatives of a function of several variables is a "partial differential equation"
All you're doing here is giving definitions of a few terms, a very long way from being able to solve ordinary differential equations (involving single-variable functions) or partial differential equations (involving multi-variable functions).
BTW, what does having a new avatar have to do with understanding anything?
Thanks ,
First you have a function f(x)
Then you can take the derivative of that function from first principles
Then you get f'(x) or dy/dx
That dy/dx , the slope of the curve (derivative) at a given point is a number .
I have been unnecessarily thinking about the cause behind why differential equations have dy/dx or f'(x) in them .I guess there is no need to think about it that way .
In a sense, these are equations where the " input data" is given in terms of partial derivatives: you are given a numerical relation involving an unknown function and some of its partial derivatives and your goal is to identify the function(s) satisfying said relations, e.g., you are given that
## a(x) \frac {\partial^2 f}{\partial x \partial y} + b(x)f=c(x); a(x), b(x), c(x)## are functions, and you need to figure out which functions f satisfy the equation. One you have likely seen is the Laplacian of a function ## U=U(x,y,...): U_{xx}+ U_{yy}+...=0## for a function U of many variables, or the Cauchy-Riemann equations , :https//en.wikipedia.org/wiki/Laplace_operator and https://en.wikipedia.org/wiki/Cauchy–Riemann_equations respectively
Differential equations are equations that involve the derivatives of various orders of some unknown function f. These derivatives represent the rates of change of some quantity with respect to some other quantity. You don't start off knowing the function, so it makes no sense to talk about finding its derivative.
For example, a mass on a spring, with no damping force, can be represented by the differential equation ##m \frac{d^2 }{dt^2}\left(x(t)\right) + kx(t) = 0## or ##mx''(t) + kx(t) = 0##. Solving this equation involves finding the position x(t). See https://en.wikipedia.org/wiki/Harmonic_oscillator#Spring.2Fmass_system
A derivative simply specifies the rate at
which a quantity changes. In math terms, the derivative of a function f(x),
which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates
how f(x) is changing at any value of x. The function f(x) has to be continuous
at a particular point for the derivative to exist at that point.
which a point mass quantity changes. In math terms, the derivative of a function f(x),
Which one is the independent variable and the dependent variable here?
Look at what you quoted in post #9.
I don't know why you are asking questions about partial differential equations if you can't look at an equation and tell which variable is dependent and which is independent.
Ok , The independent variable is x. The dependent variable is f(x)
In this ,
The function 1 , 4 , 5 are functions of several variables right ?
In this ,
Correct, and only in this case, with many variables, does it make sense to talk about partial derivatives.
A derivative simply specifies the rate at which a point mass quantity changes. In math terms, the derivative of a function f(x), which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates how f(x) is changing at any value of x. The function f(x) has to be continuous at a particular point for the derivative to exist at that point.
In a sense, these are equations where the " input data" is given in terms of partial derivatives: you are given a numerical relation involving an unknown function and some of its partial derivatives and your goal is to identify the function(s) satisfying said relations .
Partial derivatives are a kind of extension to functions of several variables such as f(x,y) . if you keep y constant, e.g. at Y1 then the partial derivative wrt x of f is the derivative of the now single variable function f(x,Y1)
the "wave equation" and
the "heat equation "
are such types of equations right ?
This quote is missing context. In general , derivatives aren't about how point mass quantites change.
Do a web search for "wave equation" and "heat equation".
What is a differential equation ?
It is an equation involving an unknown function (solution) and its derivatives
This much is OK , right ?
If you're interested in differential equations, get a textbook or look at an online course. Any textbook on differential equations will have a definition of the term, as will online sites such as Wikipedia.
Thanks , Found a good material online .
http://ncert.nic.in/textbook/textbook.htm?lemh2=3-6
The answer to your question is true. For example, U(x,t) is a function that depends on x and t. X and t are independent. Do you think is possible for a dependent function to have derivatives as functions?
  • · Replies 18 ·
