awholenumber
- 200
- 10
If the slope of the curve (derivative) at a given point is a number .
Partial differential equations (PDEs) are equations that involve the derivatives of functions of multiple variables, such as f(x,y). They extend the concept of ordinary differential equations (ODEs), which deal with functions of a single variable. Understanding PDEs requires familiarity with partial derivatives, which are derivatives of functions with respect to one variable while keeping others constant. Key examples of PDEs include the wave equation and the heat equation, which describe physical phenomena in various fields.
PREREQUISITESStudents and professionals in mathematics, physics, engineering, and applied sciences who are looking to deepen their understanding of partial differential equations and their applications in modeling real-world phenomena.
This question has no relation to the title. Partial differentia equations are not the same thing as derivatives (even though they are related).rosekidcute said:If the slope of the curve (derivative) at a given point is a number .
Is it possible to understand partial differential equations in terms of a working example of something ?From a pdf :
Basic Terminology
An ordinary differential equation (ODE or just DE) is a system with the following ingredients:An independent variable (usually t think ”time”or x think ”position”) that derivatives are taken with
respect to.
A dependent variable, i.e. function of the independent variable, e.g. y = y(t) ”the variable y which
is a function of t”.
A multi-variable function F that describes a relationship between the derivatives of the dependent
variable (taken with respect to the independent variable)
F(t, y, dy/dt, d2y/dt2 , . . . ,dny/dtn ) = 0.
Wrong website. This is about differential equations. Before going through that you should become familiar with differentials. An introductory calulus textbook or website if the Wiki link I gave you is too abstract.rosekidcute said:Thanks for the reply ,
I was going through this website here ,
https://17calculus.com/differential-equations/
Sure. Once you're comfortable wit Algebra, Calculus I and II, there are plenty in Calculus III on partial derivativesIs it possible to understand partial differential equations in terms of a working example of something ?
I suspect you have some specific topic that interests you ?rosekidcute said:This is the only thing i could think of .
All you're doing here is giving definitions of a few terms, a very long way from being able to solve ordinary differential equations (involving single-variable functions) or partial differential equations (involving multi-variable functions).rosekidcute said:It is ok , i sort of understand it with my new avatar .
Some points i tried to narrow down .
Differential calculus - which is looking at the instantaneous rates of change of objects with respect to some variables. We have the notion of the derivative of a function
The slope of the curve (derivative) at a given point is a number
Partial derivative - A derivative of a function of two or more variables with respect to one variable, the other(s) being treated as constant.
An equation that involves the derivatives of a function of several variables is a "partial differential equation"
BTW, what does having a new avatar have to do with understanding anything?
Differential equations are equations that involve the derivatives of various orders of some unknown function f. These derivatives represent the rates of change of some quantity with respect to some other quantity. You don't start off knowing the function, so it makes no sense to talk about finding its derivative.rosekidcute said:First you have a function f(x)
Then you can take the derivative of that function from first principles
Then you get f'(x) or dy/dx
That dy/dx , the slope of the curve (derivative) at a given point is a number .
I have been unnecessarily thinking about the cause behind why differential equations have dy/dx or f'(x) in them .I guess there is no need to think about it that way .
Mark44 said:Differential equations are equations that involve the derivatives of various orders of some unknown function f. These derivatives represent the rates of change of some quantity with respect to some other quantity. You don't start off knowing the function, so it makes no sense to talk about finding its derivative.
A derivative simply specifies the rate at
which a quantity changes. In math terms, the derivative of a function f(x),
which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates
how f(x) is changing at any value of x. The function f(x) has to be continuous
at a particular point for the derivative to exist at that point.
which a point mass quantity changes. In math terms, the derivative of a function f(x),
Correct, and only in this case, with many variables, does it make sense to talk about partial derivatives.rosekidcute said:Ok , The independent variable is x. The dependent variable is f(x)
In this ,
The function 1 , 4 , 5 are functions of several variables right ?
A derivative simply specifies the rate at which a point mass quantity changes. In math terms, the derivative of a function f(x), which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates how f(x) is changing at any value of x. The function f(x) has to be continuous at a particular point for the derivative to exist at that point.
In a sense, these are equations where the " input data" is given in terms of partial derivatives: you are given a numerical relation involving an unknown function and some of its partial derivatives and your goal is to identify the function(s) satisfying said relations .
the "wave equation" andPartial derivatives are a kind of extension to functions of several variables such as f(x,y) . if you keep y constant, e.g. at Y1 then the partial derivative wrt x of f is the derivative of the now single variable function f(x,Y1)
This quote is missing context. In general , derivatives aren't about how point mass quantites change.A derivative simply specifies the rate at which a point mass quantity changes. In math terms, the derivative of a function f(x), which is depicted as df(x)/dx, or more commonly in this book, as f'(x), indicates how f(x) is changing at any value of x. The function f(x) has to be continuous at a particular point for the derivative to exist at that point.
Do a web search for "wave equation" and "heat equation".rosiekidcute said:the "wave equation" and
the "heat equation "
are such types of equations right ?
If you're interested in differential equations, get a textbook or look at an online course. Any textbook on differential equations will have a definition of the term, as will online sites such as Wikipedia.rosekidcute said:What is a differential equation ?
It is an equation involving an unknown function (solution) and its derivatives
This much is OK , right ?
