What are the Alternative Parts for L14F1,LD271 & S20102
  • Thread starter Thread starter Green Light
    parts
Alternative parts for the L14F1 transistor, LD271 diode, and S20102 IC are sought for a college project involving a power switch with an infrared proximity sensor. The original poster struggles to find these components in local shops and seeks guidance on suitable replacements. Suggestions include using a solid-state relay instead of the specified IC and any available IR diode from the local market. The importance of finding exact matches versus similar alternatives is discussed, emphasizing the function of the components in the circuit. Overall, the conversation highlights the challenges of sourcing electronic parts and the need for practical alternatives.
Green Light
Transistor (L14F1)
Diode (LD271)
IC (S20102)
While I was surfing the net in the hope of finding a Solution to this, I found a Thread Regarding the same in this Site, It was Very Helpful, But not mention the part name (code) wise, I am a newbie to Electronics/Electrical Systems and only have a slight Knowledge of them,I went about obtaining these pieces for many shops but no-one had them,Even shop keepers were not kind enough to provide an alternative.
I am making this Circuit for a Collage Project and must Submit by the Next Week.
The Circuit I am going to make
http://www.electroschematics.com/6161/power-switch-with-infrared-proximity-sensor/
The Old Thread I found on this website
https://www.physicsforums.com/showthread.php?t=476884
Please Help Me,Thanks in Advance :smile:
What do you think those parts are doing in the circuit? How critical is it that you find the exact match? Have you considered finding replacement parts that are similar? The IC is a photo isolated (I believe 4 quadrant) thyristor, do you understand its function?
Wow, after looking at the old thread, what questions do you have? It seems to have answered what you can use.
Thank you very much for you Comment :) Only a rough idea :(
I want to know whether I can use any solid state (230 V) relay instead of this Sharp one
Also can I use any IR Diode that can be found in the Local Market
Also what is an ideal Transistor instead of (L14F1)
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
